Printrbot Talk Forum • View topic - Ask Buying Tips for Printrbot Jr. (V2).
Postby Hakjoo » 2013-Oct-Mon-23-Oct
I'm very interested with Your Printrbot Jr. (V2).
I'm beginner to 3D Prining.
I have some questions before buying your printer.
1. Filament compatibility
Any other 1.75mm PLA or ABS filament can be used your Printrbot Jr. (V2).
without changing Spool?
I want to buy PLA or ABS filament in Korea because of cost.
Any other problems for printing with other PLA or ABS product?
2. Service Parts
Because I'm in Korea, I have trouble to buy your Parts & Accessories.
I hope you recommend your Parts & Accessories for Printrbot Jr. (V2)
such as 1.75mm Hot End, Tips(0.4mm). Any other else?
3. CAD/3D modeling software recommendation for your Printer
4. Shipping Charge and Good Option(for UPS)
In case Printrbot Jr. (V2)( ? kg) + 4 PLA filanent(4 kg) + Other Parts(about 1 kg)
How much shipping charge from Your site to Korea(SEOUL) ?
Thank you very much if you may say advice by addition to purchase your printer.
Hakjoo
Re: Ask Buying Tips for Printrbot Jr. (V2).
Postby RetireeJay » 2013-Oct-Tue-09-Oct
Using the forum's messaging feature, I have forwarded your query to David@printrbot.
Postby David@Printrbot » 2013-Nov-Mon-23-Nov
Printrbot: Dominate Your Prints!
David@Printrbot
PBHQ Official
Return to Buying
