Printrbot Talk Forum • View topic - Where to get long cable with connector for fan
Postby hqmhqm » 2012-Aug-Sat-14-Aug
I mounted a 50mm fan on the extruder, and now am looking for a long cable with proper connector to plug into the fan
pins on the printrboard. I used this mount http://www.thingiverse.com/thing:26775
Are these standard connectors? Anyplace I can order a cable with connector from?
hqmhqm
Re: Where to get long cable with connector for fan
Postby holmes4 » 2012-Aug-Sat-20-Aug
If it's a 3-pin connector, see .
Steve
PB+ Backer 1402
holmes4
Bowden extruder
Postby holmes4 » 2012-Aug-Sun-18-Aug
Yes, use a 3-pin extension cable. When plugging into the Printrboard, let the end with the yellow wire hang off the end.
Steve
PB+ Backer 1402
holmes4
Bowden extruder
Postby he3d » 2014-Jul-Thu-01-Jul
he3d
Return to Buying
