Printrbot Talk Forum • View topic - Taulman Bridge, 3mm, 4 rolls [TAKEN]
Postby RetireeJay » 2015-Feb-Fri-22-Feb
Due to a shipping error, I have 4 rolls of Taulman Bridge available that I won't use.
It's free, but you pay shipping. U.S. or Canada, please.
PM me if interested.
Did I say it's NOT 1.75mm, it's 3mm? (I only use 3mm, but I realize most people expect to see 1.75mm)
Re: Taulman Bridge, 3mm, 4 rolls available
Postby Mooselake » 2015-Feb-Mon-10-Feb
I'm interested and would like to try it, but I'd likely never use 4 so put me down for at least one.
I'm off on a 1.75/Metal Ubis/geared extruder tangent, but putting it on another printer is in the plans so I can go back to 3mm.
Installed the printed/hot glue spider couplers and TR8 yesterday, and did a simple test print. So far they're working good (can't say great until I print something tall enough to look for Z wobble artifacts). No trouble at all with the z steps at 400/mm, and the motors really sound different. The nuts would slide down the rod from their own weight when not stuck into the X carriage, so very little friction. Just reamed the plywood holes out a bit until the nuts were a tight fit (still loose enough to pull out, I think), likely not a permanent situation. Commercial spider couplers still sitting in the Post Office in Shanghai...
Postby plexus » 2015-Feb-Mon-10-Feb
I like Bridge. But I am in Canada. Any chance you can bend your patriocentric shipping policy? Of course I will pay for the shipping and packing and your trouble. PM me if yes. don't PM me if no.
Re: Taulman Bridge, 3mm, 4 rolls [TAKEN]
Postby plexus » 2015-Feb-Mon-12-Feb
Thanks for the opportunity to get the Bridge from you Jay!
Postby Mooselake » 2015-Feb-Mon-15-Feb
The bridge has also landed at the Mooselake Manor. It'll have to wait until the tiny filament AMU moves to a new home and the Wades is restored to it's rightful place, but perhaps they'll soon be checking the moosecave for parts for our lift bridge soon - Bridge on the Bridge!
Thanks, Jay!
Return to Selling
