Printrbot Talk Forum • View topic - delta 3d printer
delta 3d printer
delta 3d printer
Postby he3d » 2014-Aug-Sun-02-Aug
We come to the new members, delta 3 d printers, bulk, $380, the assembled, $420!
Is promoting stage, we should treasure the time!Want to buy at quickly!
buy: http://www.reprap.cn
skype:reprap.cn
he3d
delta 3d printer
Re: delta 3d printer
Postby he3d » 2014-Aug-Mon-01-Aug
Technical parameters:
1, the printing technology: the accumulation of fused deposition molding (FDM)
2, physical structure, parallel arm (delta)
3, overall dimensions: height:600 mm width:320 mm length:320 mm 4, the total weight: 10 kg (including packaging)
5, external frame: imported aluminum, steel (laser precision cutting)
6, extruder:remotely and high-speed extrusion machine
7, the print head material: copper, aluminum, polyether ether ketone material forming
8, nozzle diameter: 0.4 mm (18, J - head hotend)
9 nozzle number: single nozzle
10 and the data format: STL
11, software: Repetier host
12, print range: 160 mm diameter hight 230 mm
13, power input: AC110-220 - v
14, the power supply output: DC 12 v 7 a
15,print plate: high borosilicate glass 180 mm in diameter
16, synchronous belt wheel / 16 teeth, belt GT2
17, equipped with LCD screen
The performance parameters
1, print thickness of 0.05 mm to 4 mm
, 2, mechanical precision is 0.0125mm
3, the operating system, Windows/Mac/Linux
, 4, high-speed USB device interface or SD card
Shipping list:
1, 3 d DLT - 180 delta printer (fully assembled)
2, the power supply 1 (12 v 7 a)
3,USB cable 1
4, He3D material frame 1
5, print the test material to 100 grams
buy:
he3d
Return to Selling
