Printrbot Kickstarter LC (laser cut) model 3D printer
Postby izaklast » 2016-May-Sat-14-May
Ebay listing: http://tinyurl.com/jpdkq3p
Heavily used Printrbot from the original Kickstarter run. This is a birch frame that was laser cut to save cost. It printed fine for years with a lot of maintenance and is ready for retirement. It will work again just fine if the buyer is willing to put maintenance into it. Otherwise, the stepper motors, control board, extruder, and all the metal hardware are in perfect working order for spare parts. This machine needs a lot of work because the birch and plastic parts wear down after so many hours of printing. I added a custom relay for the power supply after the plug on the main board melted There are steel braces and a custom cut steel bridge piece to give the entire bridge and print deck rigidity. If you want a DIY printer that needs constant maintenance or just a set of motors and parts for a similar printer, this is for you. Includes power supply with "power tower" upgrade (holds spools on top).
PM me or comment if interested.
izaklast
Return to Selling
