Printrbot Talk Forum • View topic - Play Hard! 8" HEATED Y axis upgrade!
Postby Mach-Chris » 2015-Aug-Sun-19-Aug
As some of you may have already seen, we've been PLAYing (see what I did there?) with making the PB play a little better suited to some more versatile printing that the Simple and Plus models boast.
As a result we came up with the "Play Hard!" upgrade. This upgrade takes the Y axis to 8" for a little more room to play with, and also has the option to heat the bed. It is, of course, MIC6 plate :)
I have a handful of pre-production units available. If anyone is interested PM me or email.
Here are some pictures:
Mach-Chris
Re: Play Hard! 8" HEATED Y axis upgrade!
Postby Mach-Chris » 2015-Aug-Tue-16-Aug
I think I found a print that does a good job of showing off and benchmarking the capabilities of the Printrbot Play (Hard!) combo. The Toyota 22-RE engine block (75% original scale)
Mach-Chris
Postby Mooselake » 2015-Aug-Fri-12-Aug
That's pretty impressive Chris.
Even more so since you seem to have printed with the Play on it's side. Guess that all metal enclosing frame really does work :)
Postby Mach-Chris » 2015-Aug-Fri-15-Aug
It's that printing in space method I've been trying out :P
Haha. My iPhone pictures always end up sideways, even if I save them rotated. It drives me mad. Probably a resolution thing. Even now. They show up in tapatalk on my phone right side up. Just not on my computer lol.
Mach-Chris
Re: Play Hard! 8
Postby thawkins » 2015-Aug-Fri-19-Aug
Return to Selling
