Printrbot Talk Forum • View topic - Doesn't make since the the m3? screw is 10mm of the board.
Postby Jacob » 2013-Aug-Fri-10-Aug
Got the z motors working properly but when I go to home all my extruder head hits the m3 screw sticking up from the board. Is there a flat screw I was suppose to put in the board instead of the m3 with a large head sticking out. Also when the printrbot homes all the extruder ends up off the front of the board?
Jacob
Re: Doesn't make since the the m3? screw is 10mm of the boar
Postby Tdeagan » 2013-Aug-Fri-13-Aug
Which Printrbot model are you working with? (that will help in giving specific advice.)
In general, the problem with the extruder ending up off the front of the board has to do with how you've set the Y-End Stop screw. You should be able to give it a few turns and make it stop the Y motion such that the extruder is ending up where you want.
Thingiverse Profile:
Tdeagan
Postby REPRAP SQUAD » 2013-Aug-Fri-15-Aug
Posting some pictures will help a lot with troubleshooting. A pictures worth a thousand words.
