gaps and strings
gaps and strings
Postby kbenson0616 » 2016-Apr-Tue-09-Apr
I have a 3D print with strings of filament in the interior hole and gaps on the first and final layer. What should I do?
kbenson0616
gaps and strings
Re: gaps and strings
Postby thawkins » 2016-Apr-Tue-11-Apr
kbenson0616 wrote:I have a 3D print with strings of filament in the interior hole and gaps on the first and final layer. What should I do?
Give us more information
A picture
The printer type
The filament type
The temperatures you are using
The speed you are printing at.
Postby kbenson0616 » 2016-Apr-Mon-18-Apr
Sorry I couldn't figure out how to post a picture to this forum. I see the img html tag in the full editor, but I don't see anywhere to upload the photo.
My printer is a Printrbot simple
I'm using Cura to print it.
My student used TinkerCad to create the .stl file and I loaded that model into Cura.
Temperature 210 degrees
Speed 45 mm
Filament 1.75 PLA
kbenson0616
Postby RetireeJay » 2016-Apr-Mon-20-Apr
kbenson0616 wrote:Sorry I couldn't figure out how to post a picture to this forum.
Every "Newbie" section of the forum has a posting like this one: viewtopic.php?f=16&t=6988
