very small part print not sticking.
Postby jknightandkarr » 2016-Apr-Thu-11-Apr
I need help on printing a button replacement for my digital camera. Button keeps coming off. Its less then 10mm cube and it just keeps coming off print bed even though speed set to min. My filament cooling fan not working well, so turned the speed waaaay down which helped prints for now.
How can i fix this? Thanks
Joe
~Starfleet Captain Joe R.
jknightandkarr
Re: very small part print not sticking.
Postby frankv » 2016-Apr-Thu-13-Apr
Tried printing with a large brim?
Postby jknightandkarr » 2016-Apr-Thu-16-Apr
Will try that and see if that helps.
Joe
jknightandkarr
Postby RetireeJay » 2016-Apr-Thu-17-Apr
Also try adjusting the clearance of the nozzle to the bed. If you get a good smoosh, it should stick. Brim is typically needed for larger objects. However if your object is more than twice as tall as it is wide, then maybe brim will help.
Postby jknightandkarr » 2016-Apr-Sat-08-Apr
The brim helped, and got my button printed this time with no issues. The buttons first layer is 5.8mm dia. lol Now gotta design the ring that goes around the button that will hold the button on the camera.... Stupid dog. lol
Joe
jknightandkarr
Postby thawkins » 2016-Apr-Sat-19-Apr
jknightandkarr wrote:The brim helped, and got my button printed this time with no issues. The buttons first layer is 5.8mm dia. lol Now gotta design the ring that goes around the button that will hold the button on the camera.... Stupid dog. lol
Joe
You should look at using a raft for small parts.
