Printrbot Talk Forum • View topic - Simple Metal stops moving and just extrudes a blob
Postby keeleon » 2015-Nov-Wed-00-Nov
keeleon
Re: Simple Metal stops moving and just extrudes a blob
Postby cacb » 2015-Nov-Wed-10-Nov
The message "Recv: Error:Line Number is not Last Line Number+1, Last Line: 365" certainly looks like a communication problem to me. I did see the exact same thing when I printed from Windows when my printer was new. In my case the USB connection was lost at different times in the same print just like you explain. You could always try another USB cable and see if it helps, but I think this is a problem that has a cause somewhere in Windows. I kept my USB cable and simply printed from Linux instead and the problems were gone.
cacb
Postby keeleon » 2015-Nov-Wed-11-Nov
Well, like I said, I THINK the comm error is because I unplugged it. I let the blob go once last night, and it did like 6 quick bursts of the extruder, and then proceeds to print like normal. Except now theres a big blob that catches on the head and rips the print off, so it still cant continue. I've tried multiple cables, and I've even tried the SD card, and it did the same thing there too. :( I also flashed the firmware to rev 5.0
keeleon
Postby seanc » 2015-Dec-Tue-02-Dec
Did you ever figure this out? I just got a printrbot simple and it does the same thing. I have had to prints now where it just stops for a second and extrudes a blob. Currently on Windows. Have reflashed the thing twice now (due to other reasons).
Edit: I have done full prints where it did not stop and blob.
seanc
Postby seanc » 2016-Jan-Fri-23-Jan
Not exactly sure what the issue is. Strange that all axis stop moving but the extruder keeps chugging away... Think I will have to try different software.
seanc
Postby accuprintr » 2016-Jan-Fri-10-Jan
I was told by support to flash the firmware and it fixed the issue. My printer was also loosing connectivity in Windows 10, so I decided to use Windows 8.1. Here is a link to a guide on how to flash your firmware. https://printrbot.dozuki.com/c/Firmware
I had several cases when printer would just freeze mid print and would not be detected by computer. After I flashed the firmware the printer was detected again.
Proud owner of:
Printrbot Simple with Simple XL Upgrade kit, Printrbot Jr. V1/Jr. V2, Printrbot Simple Metal and Printrbot Original.
accuprintr
Postby seanc » 2016-May-Mon-12-May
Flashed firmware multiple and continued with the issue. Downgraded to a older firmware (forget what version) and so far have done 2 longer prints and no blobs. It was happening previously on even very short prints (5 min), so hoping it will continue to function properly. :)
seanc
