Printrbot Talk Forum • View topic - Printed reproducer for old Victrola
Postby MartyS » 2019-Mar-Mon-19-Mar
Just for fun I tried designing and printing a reproducer for my Victrola, worked much better than I thought it would.
Not sure if embedding is possible here so here's a youtube link to 30 seconds of it playing a record.
https://youtu.be/_-UfqZc5rBA
MartyS
Re: Printed reproducer for old Victrola
Postby olendorf » 2019-Mar-Tue-05-Mar
That's crazy. Old tech meets new tech. Can't believe it works. Sounds pretty good too.
olendorf
Postby RetireeJay » 2019-Mar-Tue-12-Mar
That's amazing! Is there a metal needle that follows the groove in the record? Did you design this yourself or find the design somewhere?
Postby MartyS » 2019-Mar-Wed-10-Mar
MartyS
Here's a closeup picture:
MartyS
Postby RetireeJay » 2019-Mar-Wed-13-Mar
So the arm is printed as a "bridge" at the same time as the diaphragm and the rim all as one unit?
I looked at an online description of how to rebuild an original, and it had an unbelievable number of parts: mica diaphragm, gaskets, assembly screws, adjusting screws, even adjusting springs! And yours has two parts! Bravo! :geek:
Postby MartyS » 2019-Mar-Wed-15-Mar
MartyS
Oh, and the original on my Victrola doesn't have mica, it's a metal foil diaphragm, but it does have a lot of parts, including very tiny ball bearings that fell out a few years ago as the rubber ring holding them in decayed, found a source for the bearings but it was a pain getting them in.
MartyS
Return to Showcase!
