by RetireeJay » 2019-Feb-Tue-15-Feb
The old "Sensor" razor came with a caddy that held the razor and a cassette of 5 cartridges. But the new Mach 3 doesn't come with a case. This project provides a caddy, useful both in the bathroom and for traveling. The STL is at
To be honest, I printed this on my Prusa, but it could have been on the Printrbot.
