Printrbot Talk Forum • View topic - Music instrument tuner holder
Postby Jack Crow » 2017-Dec-Sat-10-Dec
Hi all,
Been on a trend with these various portable instrument holders.
There is a dude up the block from where I work that repairs music gear.
He has the same issue I do with portable instruments.
In this case the tuner is a tall, narrow device with nill footprint.
You look at it sideways and it falls over.
So this is what I came up with.
The base and pivot have been recycled.
Been using this for a while with good results on the DMM's and frequency counter.
Couple of points.
The Right Angle bracket is from the local hardware store.
Some are 2.5 inches and others are 3 inches.
Some have inline holes, and others have holes offset to keep wood from splintering.
So now I have two designs for the plastic part that covers the angle bracket.
I also repeated the 'bolt pattern' on the lower plastic part.
Used 10mm square pattern down the length of the part.
This is the instrument holder it's self.
The Tuner is a fairly tall but narrow box.
Slides in from the top.
This is the unit built up.
The pivot is installed in the base of the unit.
The fully built up unit.
That is the project of the day.
It will be delivered Monday to the client.
More when I know more.
Jack Crow aka Radio Mike in VB
Jack Crow
Return to Showcase!
