Cyclone pcb cnc
Cyclone pcb cnc
Postby EddB » 2015-Aug-Mon-03-Aug
My first attempt at a cnc. It is the Cyclone PCB cnc using ramps 1.4. The red is abs prints and black is pla prints. Finally moves correctly and control is tuned. Still working out the self leveling cutterhead. Expect my first cuts this week.
In the background is my first printed printer. It's the ob1.4 using open beam 1515 and a lot of custom designed parts. Works great, but my printrbot simple (makers) is still faster and has a larger print area than the ob1.4's 200x200mm.
All parts. For both printed with my Printrbot Simple maker's 1312 (v2 xl)
Ed
EddB
Cyclone pcb cnc
Re: Cyclone pcb cnc
Postby killbox » 2015-Aug-Mon-10-Aug
those are some interesting looking gears you got there. hows the backlash on them?
Redesigned JonBot printed in XT and reinforced with MDF over structure
Ramps 1.4
LCD
E3D V6
8x8 Hotbed
smoothieboard
*Coming soon* Rocking duel exturders
killbox
Re: Cyclone pcb cnc
Postby EddB » 2015-Aug-Tue-02-Aug
killbox wrote:those are some interesting looking gears you got there. hows the backlash on them?
They are the ones designed for the cyclone pcb cnc. They don't appear to have any play at all. But then again I haven't run any pcb's yet. I intend to replace them with some herringbone style gears, but want to get all the firmware set up as they have it designed and working well before I mod the hardware/firmware. Got tons of ideas to "improve it"! :twisted:
Ed
EddB
Re: Cyclone pcb cnc
Postby killbox » 2015-Aug-Tue-14-Aug
ah yes the "improve it" ideas have been hitting me hard
Ramps 1.4
LCD
E3D V6
8x8 Hotbed
smoothieboard
killbox
Return to Showcase!
