How do you remove ABS support material
Postby hqmhqm » 2012-Jul-Wed-11-Jul
I am using Slic3r 0.8.4 , and using it's feature to add support material for overhangs.
Even though the support material is a single 0.5mm thickness, it's still tough to remove, the ABS plastic is so strong.
Does anyone have any tips for easily removing support material, or config params for Slic3r that make it easier to remove?
hqmhqm
Re: How do you remove ABS support material
Postby mikemwa53 » 2012-Jul-Wed-11-Jul
A Sledgehammer......OK maybe not. About all you can do is use cutters, a file or a Dremal tool.
Sooooo much to do
Sooooo Little time!!!
Montgomery, IL. USA
mikemwa53
Postby Jason_Read » 2012-Jul-Sun-03-Jul
I use a scalpel (be very careful with this method though), also for cruder removal I will often start with needle nose pliers (grip the support and twist slowly and gently), these methods combined have proved very successful, so far
then for final smoothing and clean up I use a small set of diamond files.
Don't feed the monsters it only encourages them! LC international backer #105
Jason_Read
Postby KennyB » 2012-Sep-Thu-19-Sep
On parts that have long straight supports that can be accessed I've used a really sharp chisel. I place it flush along the edge of the support and tap it lightly with a mallet. I can get a pretty clean cut with little cleanup.
KennyB
Postby CL1 » 2012-Sep-Fri-00-Sep
KennyB wrote:I've used a really sharp chisel.
A box or pack of single edged razor blades can perform stand-in duties as *really sharp chisels* and work well for other scraping and cutting 3DP needs as well.
CL1
CL1
Can update firmware
Postby rsilvers » 2013-Apr-Mon-19-Apr
Small snips or those toenail scissors from a drug store.
rsilvers
Return to Post processing
