'Liquid Poly (similar finish to acetone - less toxic!)
Postby EvaMMF » 2013-Oct-Thu-05-Oct
Humbrol 'Liquid Poly - paint it onto your (ABS) printed model. £4.50 for a 28ml bottle.
Melts the top layer of the plastic, can be applied using a paintbrush, which is a nicer process than the acetone steaming.
Creates a smooth shiny/polish finish. See pics below, after painting, and surface before painting. Also if you want the model you can download it here - http://www.myminifactory.com/object/view/491/Fuming-Buddha
http://www.myminifactory.com/ - 3D Printable File Sharing Platform
Re: 'Liquid Poly (similar finish to acetone - less toxic!)
Postby arez9438 » 2014-Jan-Thu-05-Jan
Very cool! Just may have to try this. Thanks for the heads up!
Return to Post processing
