Heated Acetone Vapor Bath
Postby mikemwa53 » 2013-Sep-Sat-12-Sep
I had heard of using a heated acetone vapor bath before but never tried it until now. It's quick and works real good. These are a couple parts I wanted to smooth out.
All I did was use a wide mouth Mason jar and some Aluminum foil for the cover with a hole in it to hang the part from. I put about 1/8" of acetone in the jar, set my heated bed to 90 degrees C, sat the jar on the heated bed and let it warm up some. I don't know how warm the jar got but it wasn't near 90C.
It only took about 5 minutes in the vapor bath and this is how it came out. Pretty smooth and much stronger parts.
If you try this make sure you hang the part somewhere for a while because when it comes out of the vapor bath the surface is soft and gummy but will harden up real nice after it airs out.
Sooooo much to do
Sooooo Little time!!!
Montgomery, IL. USA
mikemwa53
Return to Post processing
