Scrap parts
Scrap parts
Postby mikemwa53 » 2012-Aug-Sun-11-Aug
I'm building up a pretty big pile of scrap parts and small pieces of filament.
Does anyone know of any reason to keep them or should I just throw them in the trash or recycle bin?
Sooooo much to do
Sooooo Little time!!!
Montgomery, IL. USA
mikemwa53
Scrap parts
Re: Scrap parts
Postby Dick Brewster » 2012-Aug-Sun-12-Aug
There is no reason to keep them unless you plan to start recycling the plastic yourself such as making your own filament.
AFAIK, most recyclers only use plastic that is easily identifiable as to what type of plastic it is i.e has an identifying mark on it. You will need to contact your local recycler to find out how they do it.
Most recyclers will just send mystery plastic to the landfill. If it's going to the landfill eventually, you will be doing the recycler a favor by not sending it to them
Backer #30 Lincoln California, Home of the Printrbot
Dick Brewster
Layer 100 of 1234
Re: Scrap parts
Postby mikemwa53 » 2012-Aug-Sun-12-Aug
That's pretty much what figured too. Thanks.
Sooooo much to do
Montgomery, IL. USA
mikemwa53
Re: Scrap parts
Postby mdfast1 » 2012-Aug-Sun-12-Aug
Dick Brewster wrote:There is no reason to keep them unless you plan to start recycling the plastic yourself such as making your own filament.
Yup, they are working on a filament reclaimer. http://filabot.com/. As of now I'm tossing my scraps.
UBIS 13
Printrbot LC+ - Operational
Printrbot Original- Donated
GT2 - 20 Tooth Pulleys
GT2 Belts
Brass Threaded Rods
Spur Gears from drawcut
.35mm nozzle
mdfast1
Re: Scrap parts
Postby scantrontb » 2012-Aug-Tue-23-Aug
granted, it won't take ALL of your scrap bits, but if you're using ABS, you can make ABS Goop from it. if you're using PLA, sorry.
PB+ #786
scantrontb
Can update firmware
Re: Scrap parts
Postby plexus » 2012-Aug-Wed-00-Aug
Recycle whenever where ever you can. :)
Re: Scrap parts
Postby knobunc » 2012-Aug-Wed-07-Aug
Heh. We should start printing the right recycling symbol into the things we print ;-)
Or get a bunch of stickers with it on it that we can put on scrap...
Backer 216, Nov. 27, 2011. (PB+)
knobunc
Re: Scrap parts
Postby FalconFour » 2012-Aug-Fri-17-Aug
I've been saving my scrap in hopes I can find a good RepRap cause to contribute it to. When someone comes up with a recycling method (I CANNOT picture this being a difficult endeavor, if we can extrude this plastic so perfectly, how couldn't we melt it back into the original spool shape again?), I hope to be able to send it there and put it back to use. I don't even care if I use it myself, I just cannot bring myself to throw this stuff in the trash... such an unbelievable waste (and a $70 1kg spool... f*&k you, Makerbot and your obscenely overpriced domestic shipping!). There has to be a better way. Until I stumble upon where to send it or how to use it, I'll just get an ever larger box ;)
FalconFour
Re: Scrap parts
Postby B4Me » 2012-Aug-Tue-06-Aug
FalconFour wrote:I've been saving my scrap in hopes I can find a good RepRap cause to contribute it to. When someone comes up with a recycling method (I CANNOT picture this being a difficult endeavor, if we can extrude this plastic so perfectly, how couldn't we melt it back into the original spool shape again?), I hope to be able to send it there and put it back to use. I don't even care if I use it myself, I just cannot bring myself to throw this stuff in the trash... such an unbelievable waste (and a $70 1kg spool... f*&k you, Makerbot and your obscenely overpriced domestic shipping!). There has to be a better way. Until I stumble upon where to send it or how to use it, I'll just get an ever larger box ;)
recheck for better sources.. buying from NL for about 24$ incl shipping per kg filament
B4Me
Return to Post processing
