Cura Plugin change filament at z for Printrbot over usb
Postby samirabaza » 2016-Jun-Thu-03-Jun
pauseAtZforRepetierv2.zip
most of us do not have LCD upgrade for out Printrbots so M0 command is not useful for us.
and of course we cannot change filament at z for another color like prusa i3 can do
now with this plugin for Cura, you can generate a G-code file and operate it by Repetier-Host and it will pause at height you set and go to a parking position you also can change wait for you to change filament with a screen message and then extrude the remaining of the previous for the amount you set , pause again to clear the parking area from filament and you can start printing again.
pretty much like lcd screen instructions of prusa i3
installation:
extract the file in Cura Plugin folder example "C:\Program Files (x86)\Cura_15.04.6\plugins"
CNC CAD/CAM engineer and post processor developer for CAMWorks CAM Software
Arduino fan
3D printer new pie
VBA C/C++ programmer
samirabaza
Return to Post processing
