Printrbot Talk Forum • View topic - Glue plastic part to Plexiglas base waterproof bound
Postby jfricher » 2015-Aug-Wed-11-Aug
Hello everyone,
I purchased a 3D printer to produce plastic letters to in-print into a cement mold.
What glue works well to make a solid waterproof bound between a 3D printed plastic part to a Plexiglas base. (I am using Hatchbox 1.75mm PLA filament)
Thanks for your suggestions.
The Best of days to you all :-)
Jean-Francois
jfricher
Re: Glue plastic part to Plexiglas base waterproof bound
Postby thawkins » 2015-Aug-Wed-22-Aug
Postby Mooselake » 2015-Aug-Thu-15-Aug
If you use contact adhesive you only get one chance since it sticks on contact. Use a piece of waxed paper between the two glued surfaces, line them up, then carefully pull out the paper.
That loctite adhesive would give you time to move the letter around. I'd also suggest using an epoxy that says it's good for plastic.
Your concrete example looks great! Do you have any more you'd care to share with us?
Postby frankv » 2015-Aug-Thu-19-Aug
Ummmm... why not print the base as well?
Return to Post processing
