Printrbot Talk Forum • View topic - What is the correct scale to use in Blender?
Postby inertianinja » 2015-Feb-Fri-23-Feb
I'm getting started with Blender for modeling. I changed the units to Metric, and the scale to .001, which seemed to make sense. I'm trying to make some parts that have specific dimensions.
I threw together a simple model, defining its dimensions in millimeters.
When I go to this scale, however, the world grid almost disappears, and the zoom increments become too large.
Also, when I went to load the STL in a slicer, the units were all off.
So, what should I be doing with Blender's world scale to create models with specific dimensions?
inertianinja
Re: What is the correct scale to use in Blender?
Postby davec » 2015-Feb-Sat-00-Feb
Here are the settings I used. Have done a few things and I'm satisfied.:
Default Startup Settings
3rd picture on right - Display and Edit Select Meteric Scale .001
N -> adds Tool Panel on Right
Display Check Grid Floor Lines: 10 Scale: 1.000 Subdivisions: 10
Ctrl Alt U -> User Preferences Interface -> uncheck "Show Splash"
Themes -> User Interface -> Axis Colors
-> 3D View -> Grid ->1 - 1 -1
Ctrl U -> Save as Default
Hope this helps
davec
Postby inertianinja » 2015-Feb-Sat-12-Feb
I don't think that solved the issue i'm having.
see attached pic:
inertianinja
Postby davec » 2015-Feb-Sat-21-Feb
Press using the num pad - 7 = top view
5 = ortho view
Ctrl + a = set Scale to 1
then zoom in till object fits the screen.
davec
Postby davec » 2015-Feb-Sun-01-Feb
Did you notice on your screen in the "N" panel the scale is x=50, y=190 and z=3 ?
If you have the cusor on the object and press "ctrl + a" it will let you set the scale to 1.
Any time you make a change to the object check to see if the scale changed.
davec
Return to CAD & design
