Slicer errors
Slicer errors
Postby Mindy45 » 2014-Jun-Thu-13-Jun
Another Newby Question.
I keep getting this error code . The object looks fine but could some kind soul tell me where I am going wrong please and how do I correct the file.
Regards Chris Lewis
Mindy45
Slicer errors
Re: Slicer errors
Postby RetireeJay » 2014-Jun-Thu-14-Jun
Is this an object that you designed, or one you downloaded from thingiverse (or somewhere)? If it's downloaded, try repairing it using Netfabb (as suggested in the error message). If you designed it, maybe you need to study how your CAD system works in order to create objects that have a consistent, closed "skin." Sometimes adding two or more component parts together can create an object that looks OK on screen but has hidden flaws because of how it was built. Different CAD programs handle these chores differently, so there's no one answer on how to fix it.
Return to CAD & design
