Printrbot Talk Forum • View topic - Scaling problems with Autodesk inventor
Postby Ggalisky » 2014-Jun-Sun-21-Jun
I am using autodesk inventor 2014 and when export my files into .stl they are scaled way down. Anyone else experiencing this?
Ggalisky
Re: Scaling problems with Autodesk inventor
Postby RetireeJay » 2014-Jun-Sun-21-Jun
Keep track of your units. CAD programs work in generic "units" that mean what you tell them to mean. Inches, millimeters, meters, furlongs, light-years; a unit is a unit; the core design software is units-agnostic. But if you design in inches and then try to print in millimeters you'll get an object only 1/25.4 the size you expected. Fortunately, there are options in most CAD programs to convert the STL file to millimeters. Or you can "Scale" in Slic3r to convert from inches to mm. (The whole body of software for the Printrbot works in mm, so don't try to force it to work with anything else.)
Postby marmil » 2014-Jun-Sun-22-Jun
I initially was working in inches since that's what I've always worked in before getting into 3d printing, but shortly just decided to switch and do all my modeling for 3d printing in mm since it makes exporting and importing much simpler between the different 3d printer related softwares.
(Digital calipers that can switch back and forth between inches/mm with a button push are great! And I got myself a new tape measure with both inches and mm to help myself adapt. :roll: :lol: )
If you're loading STL files in Repetier Host double check your import settings under: Config -> Units of Imported Objects
+ [color=#BF0000]•
marmil
Postby jeffro » 2014-Jun-Mon-09-Jun
Harbor freight has a decent ditital caliper that does metric and inches for around 10 bucks. I picked one up about a month back and its been great. Compared it to the nice dial calipers we have at school and its probably more accurate.
It seems everything in the CNC/3D printing world is metric, so i just learned to adapt.
jeffro
Postby bck » 2014-Jun-Thu-00-Jun
When using export after selecting .stl as filetype,
there's an "options" button, in that menu set your units to what you used when creating your part (I guess it's set to cm, and you'll have to set it to mm)
bck
Return to CAD & design
