LM12UU Bearing Block
Postby benwis » 2014-May-Sun-03-May
Hello!
I've built my Printrbot almost entirely from scratch, and I recently started work on the XR Upgrade. I was wondering if anyone had the cad file for the LM12UU Aluminum bearing blocks. I was wondering what diameter hole they used for the correct press fit of the two individual bearings. I was also wondering what would be correct for the LM8UU, because I have some of those lying around as well, and the 8mm shaft that goes with it. I'm afraid I don't know much about press fit tolerances and what not.
Can anyone shed any light on press fit tolerances? I'd rather waste as little time on the CNC mill as possible.
Thank you,
Ben
benwis
Re: LM12UU Bearing Block
Postby REPRAP SQUAD » 2014-May-Sun-10-May
I am not the master of press fit parts into aluminum but, I have a friend who is. I can ask about the lm12uu bearings. Just an FYI, there is a difference between the lm12uu that printrbot used in the earlier days and the lme12uu that they use now. A lot of the files that printrbot released are for the lm12uu that they only used for a little bit.
I'll ask about the lm12uu for you and get back to you asap.
http://www.enviousmods.com
Postby REPRAP SQUAD » 2014-May-Sun-11-May
My buddy is out and about right now so he will give me an exact number when hes home. He said if he remembers correctly its a couple of a thousands smaller but, I can get a better number when he has time to look at them.
Postby benwis » 2014-May-Sun-12-May
Thank You. If I could get numbers for the LM12UU, LME12UU(they're different?), and the LM8UU that would be awesome!
I'm also curious how you arrive at those numbers. I think there are different classes of fit as described here:
search URL engineersedge class fit
Odds are I'm going to have to shove bearings in some other place soon, so I'd be awesome to know how to do it correctly for different diameters of bearing. Thanks again!
benwis
Postby REPRAP SQUAD » 2014-May-Sun-16-May
benwis wrote:Thank You. If I could get numbers for the LM12UU, LME12UU(they're different?), and the LM8UU that would be awesome!
Yes the lm12uu and lm12uu are different. Typically the lm12uu will have a larger diameter by about 1 or more mm than the lme12uu. Printrbot now uses the lme12uu and they are supposedly better. Im building that aluminum plus v2 and I am going to use the lm12uu to see how they work. If they dont work well than I will have to bore out the holes a bit to fit the lme12uu.
We typically use a large shop press to press fit our bearings. I'll get you the exact numbers once they are sent to me. Being mothers day and all it might take a bit. Here's some pics of the aluminum plus that we are building.
Postby benwis » 2014-May-Sun-17-May
That's very nice. I'm building my own new machine as well, though I don't have any photos. I hope it looks at least as good as yours.
I've got access to a positively gigantic allen press, so I'm not worried about getting the thing in there if the holes are right.
No terrible hurry :) I'm probably going to do the milling work next weekend, I can always change the CAD model. I just wish I could find some kind of tutorial or something on press fits. I'm thinking I'm going to need to find a good machining book. Maybe Machinery's Handbook or fitting and machining by ron culley
benwis
Postby Jon Lawrence » 2014-May-Sun-18-May
Here is one source. Scroll down to page 9 for housing tolerances
http://www.lunabearings.com/new/Linear_Ball_Bushing.pdf
Press fit is a J7. On a 30mm translates to +14 / -11 micrometers.
Jon Lawrence
Calibration mode.
Postby REPRAP SQUAD » 2014-May-Sun-18-May
Thanks. We've poured a ton of time designing, printing and building this plus. I have a plus v2/2.2 hybrid that was built from scratch as we'll. the only parts we didn't make was the wood pieces and a couple of months ago we added pbs dual extruder.
It's a great platform and I've done a ton of mods to it so if you ever have any questions pls let me know.
Postby benwis » 2014-May-Sun-19-May
Why are the fits both over and under the desired hole size? At any rate if I read that datasheet and this one correctly:
mdmetric CH6.8wGO.pdf (Still won't let me add links)
Then the hole size for press fit is as follows:
Lm12UU Outer Diameter: 21mm
Press Fit Hole Size for J7 fit: 20.991 to 21.012mm
LME12UU Outer DIameter 22mm:
Pressit Fit Hole Size for J6: 21.995-22.008mm
LM8UU Outer Diameter: 15mm
14.99mm to 15.010mm
LM8EUU Outer Diameter 16mm:
15.995mm-16.006mm
They give a moderate range, so I'm not sure where to aim in that area. I'm kinda thinking slightly smaller than the desired hole, but I've got no experience with these things. I'd be curious to see what the other guy has to say :)
benwis
Postby Jon Lawrence » 2014-May-Sun-20-May
The reason for the + AND - range is reality hits somewhere in the middle. Those tolerances are based on a statistical deviation that you can reasonably assume to be somewhere in the middle. In reality, all machinists worth their salt will make holes on the small size of the tolerance and shafts on the large size of the tolerance. The reason, there is still room for correction if you leave a little meat on the bone.
In addition, just because the theoretical number may be over the ideal dimension, in reality the hole will not be perfectly round or perfectly smooth. Combine those and you still get a light press on a long bearing surface like the LM12UU.
It's late, and I am tired, so hope that made some sort of sense.
Jon Lawrence
Calibration mode.
Postby REPRAP SQUAD » 2014-May-Mon-20-May
If you want to pm me your email info I can send you his contact info as he is quite the machinist. I'm sure you can pick his brain.
Postby benwis » 2014-May-Mon-20-May
That would be helpful. It looks like I'm going to need to hire a machinist to get that fit cut, and it's pretty hard to find any. Would he be interested in running a couple prototypes for a fee?
benwis
Im sure he probably could. Ill ask.
My email is reprapsquad@techie.com. email me and ill get you guys connected.
Postby FACTEngineering » 2014-Jul-Tue-18-Jul
Greetings,
I'm Cary and I own and run the machine shop that makes the LM12UU bearing blocks for Printrbot. As far as the hole sizing for the press fit goes we simply tune the size for a light feel on the press. We also have to chase the hole size throughout the day as the temperature of the machine changes. It seems that the best fit for the 12uu bearings is about .0005" undersize, but again, we adjust if by feel at the press.
One thing to be aware of is that if the hole is too tight you can actually compress the bearing down to a smaller size and then when you force the 12mm rod into it it will not roll nicely or it will destroy the bearings or it will quickly cause the rod to pit and flake off the hardened surface.
-Cary
FACTEngineering
Return to CAD & design
