Printrbot Talk Forum • View topic - Support material bonding to object
Postby hugerobots » 2014-Feb-Mon-13-Feb
For me this problem has only started with the latest version of Slic3r.
Has anyone else noticed that support materials are using a full perimeter that surrounds the supports now? I find that I now have to decrease my support material extrusion setting to 70% in order to decrease the threshold it has to bond to the actual model. Any higher and it bonds fully, resulting in it being totally fused with the model.
In previous versions the support material wouldn't have a perimeter at all, leaving the scaffolding bare and easier to remove.
Is there a setting for to remove the support perimeter or is it permanently in there now?
hugerobots
Re: Support material bonding to object
Postby REPRAP SQUAD » 2014-Feb-Mon-13-Feb
I've noticed the same with the new version of slic3r.
Postby killbox » 2014-Mar-Sun-10-Mar
I too have noticed this, and i can't figure out how to stop it.
Redesigned JonBot printed in XT and reinforced with MDF over structure
Ramps 1.4
LCD
E3D V6
8x8 Hotbed
smoothieboard
*Coming soon* Rocking duel exturders
killbox
Postby shaddii » 2014-Apr-Tue-14-Apr
Did anyone ever find out how to turn the support perimeter off? the perimeter generated around the support is really messing things up.
2014 Printrbot Simple
XL volume / tower upgrade
Aluminum Direct Drive
shaddii
Postby PxT » 2014-Apr-Tue-15-Apr
Slic3r 1.1 (beta) is out and has a "pillar" support option which is supposed to be easier to remove than the old style. I haven't tried it yet but it might be worth a shot.
Postby disback » 2014-May-Wed-16-May
Just tried the pillar support and I'm getting wonky results (yes I know this is an experimental version!). I've been avoiding using supports in all my prints for the last 3 months ever since they added the whole "perimeter around the support material" feature. Is there anyone on this forum who can get our feedback to the Slic3r team about this? I want the old algorithm for support material back. I tried rolling back to an older version, but I'm scared by all the error messages that are popping up because the config files are confusing the software since alot of the new features didn't exist. :oops:
Los Angeles, CA
System Details: Printrbot LC V1.0
*GT2 Pulleys/Polychain
*Glass print bed
*ACME Threaded Z-axis
*Other shenanigans
disback
Postby PxT » 2014-May-Wed-17-May
You can easily give your feedback to the Slic3r team directly. See https://github.com/alexrj/Slic3r/blob/m ... IBUTING.md
Postby opiesche » 2014-Jul-Sun-09-Jul
Just for those who are still having trouble with Slic3r's support fusing to the object: you can turn the support perimeter off by doing the following:
-open Slic3r/lib/Slic3r/Print/SupportMaterial.pm in a text editor
-find the generate_toolpaths subroutine, and in it, the following section:
# base flange
if ($layer_id == 0) {
$filler = $fillers{interface};
$filler->angle($self->config->support_material_angle + 90);
$density = 0.5;
$flow_spacing = $object->print->first_layer_support_material_flow->spacing;
} else {
# draw a perimeter all around support infill
# TODO: use brim ordering algorithm
push @paths, map Slic3r::ExtrusionPath->new(
polyline => $_->split_at_first_point,
role => EXTR_ROLE_SUPPORTMATERIAL,
height => undef,
flow_spacing => $flow->spacing,
), map @$_, @$to_infill;
# TODO: use offset2_ex()
$to_infill = offset_ex([ map @$_, @$to_infill ], -$flow->scaled_spacing);
Then comment out the support perimeter generation like this:
# base flange
$density = 0.5;
#else {
#push @paths, map Slic3r::ExtrusionPath->new(
# polyline => $_->split_at_first_point,
# role => EXTR_ROLE_SUPPORTMATERIAL,
# height => undef,
# flow_spacing => $flow->spacing,
#), map @$_, @$to_infill;
#$to_infill = offset_ex([ map @$_, @$to_infill ], -$flow->scaled_spacing);
Save the file. Reslice. This should bring the support material back to the 'old style' without perimeters.
opiesche
Postby hugerobots » 2014-Jul-Sun-12-Jul
Brilliant!
I've been using the Pillars support constructs since they were available and the only difference in prints for me was that the Perimeter around Pillars supports was less close to the object's walls. With your mod this should work swimmingly with all supports again. Well done!
Now if I can only find the corresponding file in the Mac version...
hugerobots
Postby alexhb » 2015-Feb-Tue-11-Feb
I hate to bump a dusty old thread, but this would've helped me out a ton:
Slic3r support material just plain sticks to the print for me, no matter what I try, including all the above help. What finally fixed my problem was using CuraEngine instead, which allows hard X/Y and Z offsets for generating supports.
Happy Printing!
alexhb
Return to CAD & design
