Nut and bolt with homegrown CAD
Postby cacb » 2016-Mar-Fri-12-Mar
I like making software and some may remember the CSG modeller based on AngelScript viewtopic.php?f=20&t=10650
At that time it was a preprocessor to OpenSCAD, and it can still be used that way. However, I have recently been working with doing the boolean operations without OpenSCAD, because it is a challenge and because I want something a bit faster. I found an interesting library called CARVE that can do similar things, so I started looking into it. It turns out it is quite good, so I began building functionality around it. With this tool I can do almost all what OpenSCAD can do, and most of the time significantly faster.
As a test of a new feature yesterday I designed an M16 metric nut and bolt, with threads according to https://en.wikipedia.org/wiki/ISO_metric_screw_thread . Could I design it, print it so the nut and bolt fit? Here are some results:
First a view of the STL file mesh of the bolt (D=16mm, pitch=2mm) . The threads have been created by winding the thread profile about 15 times around. Then unioned with a cylinder to make a threaded rod. Then unioned that with the rounded head to make a bolt, and the other rod end slightly chamfered.
The nut is created by subtracting the threaded rod from the head, adding a 0.5mm clearance
Here are the two parts printed on my Simple Metal. 0.1mm layer, 210C, no brand PLA. Bed temperature 65C.
And yes, the threads actually fit ....
cacb
Re: Nut and bolt with homegrown CAD
Postby Mooselake » 2016-Mar-Fri-13-Mar
That's impressive!
Does that mean you've using the CARVE library within AngelScript CSG? Is there a new version to download?
Postby cacb » 2016-Mar-Fri-13-Mar
Mooselake wrote:That's impressive!
Thank you! Yes, you've got that right, there is now an alternative path where OpenSCAD isn't used. However, this carve-based route isn't ready so there isn't a new version at this moment. But I am able to use it for a few things.
cacb
Postby frankv » 2016-Mar-Fri-14-Mar
Interesting!
Where can I find out more about the CARVE library?
I'm interested in using to convert scanned meshes as .OBJ files into solids as .STEP or similar.
Postby cacb » 2016-Mar-Fri-17-Mar
frankv wrote:Interesting!
https://code.google.com/archive/p/carve/
It takes some work to figure out....
cacb
Postby Mooselake » 2016-Mar-Fri-18-Mar
frankv wrote:I'm interested in using to convert scanned meshes as .OBJ files into solids as .STEP or similar.
If you haven't already, check out meshlab (and here). It won't get you to step files, but at least it'll clean up those scanned meshes.
Postby frankv » 2016-Mar-Fri-18-Mar
Yes, I have Meshlab. Also this, which works with MeshLab and Blender http://3d-print.link/download/lunavast-cgto3dprint/ and a bunch other stuff. But nothing seems good at converting meshes to solids (yes, I know that's a difficult problem).
However, what I'm aiming to do is to take some of the myriad 3D models on the Net and edit them to make them 3D printable.
Naturally, :roll: I've started with a complex example... the Wright Brothers 1903 Flyer 3D-scanned by the Smithsonian... http://3d.si.edu/downloads/48
Tools I'm using are MeshMixer to chop the model into bits and MeshLab to simplify the meshes of each part. But I want to load it into OnShape (since that's my preferred CAD program) to edit the parts (e.g. adding tabs and pins and so on to the parts for reassembly), scaling, etc. However, OnShape won't read .OBJ files, so I'm using FreeCAD to convert to a solid and export as STEP/IGES. But the conversion re-adds all the removed complexity, and makes the object file huge and unwieldy again. :( I'm thinking maybe to use cacb's app, or the CARVE library, or whatever, to simplify the solids.
Postby cacb » 2016-Mar-Sat-02-Mar
frankv wrote:However, OnShape won't read .OBJ files, so I'm using FreeCAD to convert to a solid and export as STEP/IGES. But the conversion re-adds all the removed complexity, and makes the object file huge and unwieldy again. :(
I think FreeCAD is based on OpenCascade http://www.opencascade.com/, a "traditional" and complicated CAD B-rep representation. That is a very different animal compared to a mesh based approach. You are going to struggle very hard to convert from a mesh to a usable STEP or IGES. FreeCAD can import OpenSCAD .csg files, but it will not understand those commands that usually rely on a mesh based representation (hull and minkowski are a couple of such examples).
"nothing seems good at converting meshes to solids". Meshes are solids. I think what you are really saying is "nothing seems good at converting meshes to a STEP type model". In the general case that's impossible in a meaningful way, so I am not surprised. To make "the myriad 3D models on the Net" 3d printable you will have to stay with meshes in many cases. At least that is what I think.
cacb
Postby cacb » 2016-Mar-Sat-16-Mar
Now on Thingiverse http://www.thingiverse.com/thing:1445033 if you want to give it a try
cacb
Return to CAD & design
