Printrbot Talk Forum • View topic - Problem with my project....
Postby jknightandkarr » 2015-Oct-Thu-00-Oct
First off here's my files, the project, exported to DWG from Google Sketchup 2015 and the fixed STL file uploaded n fixed from
I had to make links of the pics, forum didnt like them lol
It's a modified version of this object. Minus the electronics.
What I have done is combined that design of the black part and combined it with features of this one:
And created something different. When I export the file to STL from Sketchup and import into Repetier Host, says it's not watertight, so I uploaded it to the modelrepair site, and the results are the stl file in the zip. the holes in the middle and on one side are covered now.... I have used that site before on models and this is the first time I have had an issue. I am not sure, but maybe the fact that I was having some issues on sketchup on my laptop might be some of the cause, but I erased most of my work, exported to STL n checked on Repetier Host, was fine, and proceded to redo work on my desktop.
And it's not just covering the holes, in the dwg file, there's 3 sections the center and 2 sides, one side isn't done, so it sits lower, the raised side is finished, and on my square holes its bigger sq. holes and bevels to slightly smaller sq. hole. I imported the repaired STL file into sketchup and thought, I'd edit the file and try again, well on the raised side with sq. beveled holes, the bevels are gone! So I don't know what the issue is... Since I found that model repair site, I have had zero probems with stuff I print. Is it my laptops doing, since sketchup has a few issues or what?? I REALLY wanted to see that printed tonight...... :evil:
Joe
~Starfleet Captain Joe R.
jknightandkarr
Re: Problem with my project....
Postby jknightandkarr » 2015-Oct-Thu-01-Oct
Ooooook...... I got more issues then i thought. Not sure how i got this in this section.... Could we move it please? Sorry about that
Joe
jknightandkarr
Postby RetireeJay » 2015-Oct-Thu-06-Oct
Topic moved to CAD and Design
Have you tried Netfabb to repair your STL file? They have both cloud and downloadable programs to fix STL's.
But maybe you need to think carefully about how you do your design. Sometimes in some programs you can create things that look perfect on-screen but they are not going to create good STL's because different "sub-parts" are intersecting with each other instead of being merged into a single larger, more complex part. Way back in 2011 or 2012 Plexus had a thread about this kind of difficulty.
Oh, and I see no reason why you would not be able to upload the pictures to the forum from your computer. "Upload Attachment"... Browse... Upload... Insert Inline.
Postby jknightandkarr » 2015-Oct-Thu-14-Oct
Thanks for moving this. The pics I didnt try n upload, just found pics on the internet, I guess one of them is too big,
I will try netfabb. Just incase, is there any free modeling programs out there like Google Sketchup? I have blender, but it kinda confuses me.
Joe
jknightandkarr
Postby PxT » 2015-Oct-Thu-14-Oct
Postby Mooselake » 2015-Oct-Thu-14-Oct
Just off the top of my antlers:
, , , , lots of other free .
I used TinkerCAD for my first printable design, I think they still offer free accounts. There's been several other free packages discussed here and elsewhere, Google is your friend and claims to do no evil.
Postby frankv » 2015-Oct-Thu-17-Oct
-- I've switched to this from FreeCAD. It's a full-featured free online service, essentially free so long as you share your designs.
Postby Mooselake » 2015-Oct-Thu-17-Oct
Of course, like Tinkercad, onshape only works if you're online. If the beaver chew through the fiber (it's happened up here...) then you're stuck, if your provider's slow (or your whole family's streaming Netflix) then so is your work, if the cloudy app's hoster pulls the plug (almost happened with Tinkercad) or drops free accounts your stuff's toast. Wouldn't use them for much beyond quick and dirty. Just saying...
Postby marmil » 2015-Oct-Thu-23-Oct
Looks like a fun project jknight. I also have switched from FreeCAD to Onshape. FreeCAD (at least with my experience) does a great job of outputting solid models and has some good modeling (and python scripting) capabilities, but it's interface is clunky. I'm loving Onshape now. Onshape allows 10 private files if you don't want to all your files public. I would totally recommend giving Onshape a try. If you watch some of their tutorial videos (they have a bunch on their website and their youtube channel) then I bet you could totally remodel your project from scratch pretty quickly in Onshape.
I've also used Autodesk's Fusion 360 some. (Also free, just sign up as a hobbyist user.) It has a lot of features and makes nice solid models, but it's interface just didn't click with me like Onshape's did. Autodesk also has a free very light weight CAD program called 123D Design, which looks good for the simplicity. I've never tried it but I've seen it being used by various makers online (The Ben Heck Show!) so people must like it.
[I still like to use Sketchup for roughing out ideas sometimes, but yeah, if trying to use it to make your final solid models for printing you do indeed have to regularly check that you haven't mucked up your modeling and broken something.]
+ [color=#BF0000]•
marmil
Postby jknightandkarr » 2015-Oct-Sun-12-Oct
Thanks for the replys. This is the first time ever I have made a 3D model with Sketchup, being water tight has been issues, but that website has always fixed them without an issue but I grabbed 123D stuff. Will look at that along with some other stuff.
Joe
jknightandkarr
Return to CAD & design
