Printrbot Talk Forum • View topic - Need to hollow an .STL file
Postby Desdemona1 » 2015-Aug-Fri-11-Aug
As the title says, trying to hollow this model so i can make this wearable. Prefer to use freeware on OS X, or willing to email the file if someone can help.
I think I'd like to do something nice for somebody. I think it's good if you smile at someone, and they smile in return. Voluntary love encourages people to create a sense of friendliness.
Desdemona1
Re: Need to hollow an .STL file
Postby RetireeJay » 2015-Aug-Fri-11-Aug
I have no idea of the shape you are talking about. But if you started with a hockey puck and wanted to make a bracelet, you can do that in Slic3r (and probably Cura also) without modifying the STL. Just specify zero thickness for the top and bottom layers, and zero infill. All that's left is the perimeter layers.
Thank you RJ, I will give it a try.
Desdemona1
Postby Desdemona1 » 2015-Aug-Fri-12-Aug
Desdemona1
Postby bbrown64 » 2015-Aug-Fri-13-Aug
Why not simply adjust the infill to about 4%. That would leave hardly any thing on the inside of the part.
Bill Brown
Tulsa, OK
bbrown64
Postby Mooselake » 2015-Aug-Fri-16-Aug
Return to CAD & design
