Oh No - thermistor fail
Postby Scozza » 2013-Apr-Thu-03-Apr
Howdy folks,
I'm in East Gippsland (Vic) and have had my bot since late last year. Due to oh so many problems with hardware, assembly etc.I only got it working this week. Now it seems the extruder thermistor has given up the ghost )-: Has anyone ordered a replacement unit from PB or located one locally with any success?
Cheers,
Scott.
Scozza
Re: Oh No - thermistor fail
Postby RetireeJay » 2013-Apr-Thu-18-Apr
Return to Downunder
