Marlin - Setting Up Cyclops Hot End
Code hacking talk
Postby orangefurball » 2015-Apr-Sat-19-Apr
Hello,
I have yet another Marlin issue. I have a Cyclops hot end which only has one heater and one thermistor, so Marlin is returning a dangerous extrusion prevention error for the second extruder because there is no temperature reading.
Obviously turning off the dangerous extrusion settings would fix it, but I would rather make it read the first and second temperature from the same thermistor without having to split the thermistor wires. Is this possible?
Thanks!
Thingybot Delta Printer
http://www.thingybot3d.com
orangefurball
Laser scintillater
Re: Marlin - Setting Up Cyclops Hot End
Postby 2Mylent » 2015-Apr-Sat-19-Apr
If i understand the question.
In my research on modifying the firmware, I saw that in the Marlin file "configuration.h" were:
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 1
#define TEMP_SENSOR_2 1
#define TEMP_SENSOR_BED 1
Therefore it is possible to have three temperature sensors to the extruder 1 for the bed.
Printrbot Simle Metal + Upgrade Heatbed / Upgrade E3D v6 / Simplify3D / Win7 64bits
http://www.2mylent.fr/Helicos/
FRANCE
2Mylent
Postby orangefurball » 2015-Apr-Sat-20-Apr
2Mylent wrote:If i understand the question.
That's actually to setup which temperature table your hotend uses. The number after the "_" is the thermistor itself, so it still wouldn't work.
Thank you though!
orangefurball
Laser scintillater
Postby Mooselake » 2015-Apr-Sun-11-Apr
See if this helps. It was the second entry when googling "configure marlin firmware cyclops" (no quotes...)
Postby frankv » 2015-Apr-Sun-17-Apr
Good find Kirk!
Looking at this, I'd say to find this line in pins.h (MOTHERBOARD == 81 means the PrintrBoard)...
Code: Select all
#if MOTHERBOARD == 8 || MOTHERBOARD == 81
This is line 1506 in pins.h in Marlin_bedlevel_simple.zip which is right for my Rev-D board. I don't know if the Rev-F file is different.
Below that, find this line
Code: Select all
#define TEMP_1_PIN         2
Change that to be the same as the TEMP_0_PIN (1 in my version). i.e.
Code: Select all
#define TEMP_1_PIN         1
I'm guessing this will be the same for other versions of the board, unless PrintrBot changed the layout between versions.
Frank
Postby orangefurball » 2015-Apr-Sun-20-Apr
Mooselake wrote:See if this helps. It was the second entry when googling "configure marlin firmware cyclops" (no quotes...)
Thanks Mr. Moose, I missed that in my Googling I guess!
frankv wrote:Good find Kirk!
Code: Select all
Code: Select all
Code: Select all
Frank
Thanks for this Frank, I'm using a RAMPS board but this should really help with my issues!
orangefurball
Laser scintillater
Postby frankv » 2015-Apr-Mon-03-Apr
OK, for RAMPS, in the latest development version you want the file pins_RAMPS_13.h, lines 112-113.
Code: Select all
#define TEMP_0_PIN         13   // ANALOG NUMBERING
#define TEMP_1_PIN         15   // ANALOG NUMBERING
#define TEMP_2_PIN         -1   // ANALOG NUMBERING
Again, change TEMP_1_PIN to be the same as TEMP_0_PIN.
Postby orangefurball » 2015-Apr-Mon-03-Apr
frankv wrote:OK, for RAMPS, in the latest development version you want the file pins_RAMPS_13.h, lines 112-113.
Code: Select all
Thank you Frank, I'll try this tomorrow!
orangefurball
Laser scintillater
Postby Mooselake » 2015-Apr-Mon-12-Apr
orangefurball wrote:Thanks Mr. Moose, I missed that in my Googling I guess!
Some days the fu is strong, some days it's weak.
May the fu be with you.
Postby orangefurball » 2015-May-Sun-22-May
Alright, I made the modifications to the pins.h page and when I go to compile I get an error. Here it is...
Code: Select all
temperature.cpp:1054: error: pasting "DIO" and "-" does not give a valid preprocessing token
temperature.cpp:1054: error: invalid suffix "_RPORT" on integer constant
temperature.cpp:1054: error: invalid suffix "_WPORT" on integer constant
temperature.cpp:1054: error: invalid suffix "_PIN" on integer constant
temperature.cpp:1071: error: pasting "DIO" and "-" does not give a valid preprocessing token
temperature.cpp:1071: error: invalid suffix "_RPORT" on integer constant
temperature.cpp:1071: error: invalid suffix "_WPORT" on integer constant
temperature.cpp:1071: error: invalid suffix "_PIN" on integer constant
temperature.cpp: In function 'void __vector_22()':
temperature.cpp:1054: error: 'DIO' was not declared in this scope
temperature.cpp:1071: error: 'DIO' was not declared in this scope
Not really sure what to do here. I cannot find "DIO" anywhere. Anyone know where to look?
orangefurball
Laser scintillater
Postby plexus » 2015-May-Sun-22-May
plexus wrote:DIO
Good find, that solved everything!
Well, actually I just forgot to change a number but I would be lying if I said that amazing band didn't help me through it.
orangefurball
Laser scintillater
Postby orangefurball » 2015-May-Tue-02-May
Welp, after messing about for the day with the Cyclops, it seems as though it just is not meant to be. Marlin has trouble with single nozzle, dual extruder setups and Repetier firmware does not have the auto-calibration needed. Looks like this hot end will be collecting dust until I find another use for it, maybe it will go on the Jonbot Plus.
orangefurball
Laser scintillater
Postby PxT » 2015-May-Tue-17-May
So did you get the firmware working but run into some other problem? Curious, because I have a Diamond Hotend (3-color, single nozzle) on the way.
Postby orangefurball » 2015-May-Tue-18-May
Yes, marlin has trouble with multiple color single nozzle hot ends I guess, so I'm probably going to stick this on my Jonbot Plus and switch to Repetier firmware.
Basically what happens is you can extrude the first color just fine, but the second (and third I suppose) won't extrude at all, the hot end simply continues to go up and up and up while ignoring all endstops and commands.
orangefurball
Laser scintillater
Postby frankv » 2015-May-Tue-19-May
Goes up & up???? Sounds like your 2nd extruder is mixed up with your Z axis?
Postby orangefurball » 2015-May-Tue-19-May
Nope, it's definitely just a Marlin bug (its a delta, X Y and Z all move up at the same time)
E3D also has on their wiki that there is a bug with Marlin and recommend Repetier
orangefurball
Laser scintillater
Postby Mooselake » 2015-May-Thu-11-May
Don't forget to create an issue for the bug on github.
Postby orangefurball » 2015-May-Thu-13-May
Mooselake wrote:Don't forget to create an issue for the bug on github.
Will do!
orangefurball
Laser scintillater
Postby PxT » 2015-May-Thu-15-May
orangefurball wrote:Yes, marlin has trouble with multiple color single nozzle hot ends I guess, so I'm probably going to stick this on my Jonbot Plus and switch to Repetier firmware.
That's weird because the Diamond Hotend guys say they have been doing all their development with Marlin.
Postby orangefurball » 2015-May-Thu-15-May
Hmph, maybe they've cracked it then? Not sure. I'm going to revisit it in a couple of weeks probably.
orangefurball
Laser scintillater
Postby frankv » 2015-May-Thu-20-May
Maybe the Diamond guys have customized their Marlin?
Postby orangefurball » 2015-May-Thu-20-May
frankv wrote:Maybe the Diamond guys have customized their Marlin?
If they did they should release their fixes!
orangefurball
Laser scintillater
Postby PxT » 2015-May-Fri-11-May
No, they just document setting the 3 sensor pins to the same value - same as what was discussed earlier in this thread. The details are on the reprap.org wiki
Postby orangefurball » 2015-May-Fri-19-May
PxT wrote:No, they just document setting the 3 sensor pins to the same value - same as what was discussed earlier in this thread. The details are on the reprap.org wiki
That's strange, I did exactly that and it didn't work. I'll have to look into it again. Thanks!
orangefurball
Laser scintillater
Return to Hack talk
