Printrbot Talk Forum • View topic - Marlin Configuration.h
Code hacking talk
Postby wd5gnr » 2015-Jan-Fri-22-Jan
Well I didn't have much progress today as everything I had done had to be backed out. I had cloned the latest Marlin from the Printrbot github. I have a build environment setup.
Did a build and loaded it. It did the bed level routine but since I don't have the sensor I decided I'd just turn it off. Did that. Rebuild. Reflash. The X/Y/Z seems backwards.
So I do a diff between the Configuration.h and the one in the source for Unified V3. Differences where I changed a few things. There are more options for MAX stops that we don't have, but all looked ok.
I could never get it all going. It looks like XYZ is inverted. But then if you do that, a home to -1 goes the wrong way. But if you set home to 1, the code assumes you have max stops which we don't.
Just as a baseline, I recompiled unified 3 and flashed it. Works fine.
So what's the magic? It looks like pins.h defines the MIN or MAX stop based on the homing direction but since that is flipped it is doing the wrong thing. But that wasn't a problem in earlier builds apparently.
Any advice?
Al Williams
Twitter: @awce_com
wd5gnr
Re: Marlin Configuration.h
Postby PxT » 2015-Jan-Sat-01-Jan
Postby wd5gnr » 2015-Jan-Sat-01-Jan
Al Williams
Twitter: @awce_com
wd5gnr
Return to Hack talk
