Printrbot Talk Forum • View topic - Ramps thermistor
Ramps thermistor
Code hacking talk
Ramps thermistor
Postby Munson » 2014-Oct-Sat-16-Oct
I switched hotend on my ramps and now I have to hold the hot end with my hand (body heat)so it gets warm enough so i can engage the heat settings.the temp reads around 22-23 degrees.any suggestions?
Munson
Ramps thermistor
Re: Ramps thermistor
Postby thawkins » 2014-Oct-Sat-19-Oct
Return to Hack talk
