G-code delay of minutes
Code hacking talk
Postby donde » 2014-Jul-Wed-15-Jul
In using an SD card with G-code on it, I would like to do this using my Simple 2014 with Upgrade Kit.
Upon powering up, turn on extruder heater, wait till it reaches printing temperature, but then wait even longer maybe up to 10 minutes.
Then continue with the normal print script, calibrating the bed level sensor, etc. That way the expanding nozzle would be included like it was
in the final sensor calibration. I don't know if a delay G-code exists, and if not I would drop the idea.
donde
Re: G-code delay of minutes
Postby RetireeJay » 2014-Jul-Wed-15-Jul
The M109 command is used to give the hot end a setpoint temperature, and the 'bot will wait until the setpoint temperature is reached and stabilized (plus 10 seconds). If you put two or three M109 commands all in a row at the beginning of your code (say, setting the hot end to 150, then to 250, then to 150, and then to your desired printing temperature) then you will get the hot end warmed up for a fairly significant time before anything else happens.
Postby donde » 2014-Jul-Wed-20-Jul
Thanks Jay, This is what I've been looking for.
Off topic, sorry
Another question, probably a dumb one. Can I convert an .stl back to openSCAD if an openSCAD file .scad is not listed? I know lots of Things on Thingiverse are shown in openSCAD also, but if not, can it be done?
donde
Postby thawkins » 2014-Jul-Thu-04-Jul
G4 Pn Wait n miliseconds
G4 Sn Wait n seconds
Postby donde » 2014-Jul-Thu-08-Jul
THANK YOU! Even easier than I thought.
donde
Postby Mooselake » 2014-Jul-Thu-08-Jul
No. At not without a whole lot of manual effort.
However, you can read an stl file with openSCAD and then modify it, if that's what you're after. It'll require some programming, and take some time if you don't have a programming background. I'd recommend starting by reading the openSCAD documentation and tutorials (and trying them) first. If you go that route you'll decide somewhere in the process that you can't do it, and banging on your head with a hammer is more fun. Ignore those feelings; you can, and it's eventually more fun than the head/hammer thing, and leave fewer physical scars.
donde wrote:Another question, probably a dumb one. Can I convert an .stl back to openSCAD if an openSCAD file .scad is not listed? I know lots of Things on Thingiverse are shown in openSCAD also, but if not, can it be done?
Return to Hack talk
