Printrbot Talk Forum • View topic - [SOLVED] Firmware Update for Windows users
Code hacking talk
Postby RetireeJay » 2014-Jan-Thu-10-Jan
Re: Firmware Update for Windows users? HELP!
Postby PxT » 2014-Jan-Thu-12-Jan
Re: [SOLVED] Firmware Update for Windows users
Postby RetireeJay » 2014-Jan-Thu-15-Jan
Rewrote the original post to show the solution.
Ouch! Spoke too soon. The old version 0022 will compile the Unified software. The new version spits out a ton of warnings and a few Errors - so no hex file is created. :(
NOTE: See Original post for the latest misadventures...
Re: Firmware Update for Windows users NOT solved - HELP!
Postby RetireeJay » 2014-Jan-Fri-11-Jan
New post to refresh and make this show up. But the OP is completely rewritten and describes the problem.
Postby Mochaboy » 2014-Jan-Fri-12-Jan
eek...
The reason you get that 9 x out of 10 is because of conflicting libraries.
I'm sorry if you mentioned this earlier but did you start from a zero'd out install? Uninstall - delete old libraries - install fresh?
Printrbot Jr born 6/13
Brass M8 Threaded Z Rod
Tool less belt tensioners
Aluminum print plate
Mochaboy
Print winner 1st
Print winner 1st
Postby RetireeJay » 2014-Jan-Fri-12-Jan
I did completely uninstall Arduino before reinstalling. There was no Program Files(x86)/Arduino directory when I started the latest install.
Are the libraries somewhere else? For Unified Marlin, I'm using a set of files that I downloaded from Github as a zip file, and I unzipped them. I didn't do anything else but put them in a directory where I can find them.
It seems strange that version 0022 always seems to work for me but I can't get the newer one to work. Why would the new one have trouble finding #included files when the old version has no trouble?
Postby PxT » 2014-Jan-Fri-12-Jan
I think the step you are missing is to rename the cores\teensy directory that Teensyduino creates.
I just did the following on my Mac and it worked, the equivalent on Windows should get you going:
* Download Arduino 1.05 From
* Download Teensyduino from
* Run the Teensyduino installer, don't install the extra libraries if it prompts
* Find the hardware\teensy directory inside your Arduino install (on a Mac this is usually /Applications/Arduino.app/Contents/Resources/Java/hardware/teensy, on Windows it will likely be something like c:\Arduino\hardware\teensy)
* Download http://blog.lincomatic.com/wp-content/u ... 286txt.zip and copy the programmers.txt and boards.txt files to the above directory (or take them from the older pre-configured Arduino install).
* Inside the above directory find the cores\teensy directory and rename it to cores\at90usb1286
* Launch Arduino, select either of the printrboard options from the Boards menu, click Verify to compile
Postby RetireeJay » 2014-Jan-Fri-13-Jan
Postby PxT » 2014-Jan-Fri-14-Jan
Postby pomonabill221 » 2014-Jan-Mon-22-Jan
In my testing to make sure things are working, I select the usbtinyisp AT90USB1286 for the board, usbtinyisp for the programmer (usb tiny in circuit programmer).
I open marlin.pde and click on verify (check mark).
It goes through the compiling process with several tabs open (blink, blinkm, configuration, configuration store, and several others) (is this correct because the pde needs to load these libraries?).
NOW... how do I create the hex file to upload using Flip? or how does the hex file get generated? or do I just select upload under file menu in arduino?
It would be nice to create a hex file so I don't have to go through this each time...
Is the marlin-marlinv1 the correct generic firmware for the PBplus v2? I did get an error that I had the wrong board, so I changed the board type to 81 (it was 1 for the makerbot).
Also, how would I go about adding the autolevel feature to the firmware in my printer? I don't want to do this until I am comfortable updating the firmware.
PBplus V2 kit.
* NOW with AUTOLEVEL!!!!
pomonabill221
Postby thawkins » 2014-Jan-Tue-00-Jan
Postby pomonabill221 » 2014-Jan-Tue-00-Jan
Thanks Thawkins!
I am running win7 64.. I found a possible hex file.... marlin.cpp.hex under users\e6500\appdata\local\temp\build29400342775130679.tmp....WOW why can't the ide save the hex file in a simpler location????
Also, the header,elf,epp,cpp,etc. files are there, but I would imagine the .cpp.hex file is what I want? It is 157k in size.
PBplus V2 kit.
pomonabill221
Postby RetireeJay » 2014-Jan-Tue-10-Jan
Postby RetireeJay » 2014-Jan-Tue-12-Jan
Postby pomonabill221 » 2014-Jan-Wed-01-Jan
PBplus V2 kit.
pomonabill221
PBplus V2 kit.
pomonabill221
PBplus V2 kit.
pomonabill221
Postby RetireeJay » 2014-Jan-Wed-09-Jan
I'm speculating here, but I think that by installing the Teensy package on top of (or into) the Arduino package, we provide "libraries" of subroutines that are needed for the Printrboard, and / or definitions of "pins" etc.
The Arduino family of hobbyist boards is based on chips from Atmel, but there are several CPU chips available, with different features and different numbers of pins on the chip. The Arduino software package tries to "hide" some of these details from the users by having their own set of pin definitions which is supposed to be constant. But to achieve the very high pulse rates needed by stepper motors and proportional heaters, the Teensy developers added to the Aduino library. Somewhere in there is a package called "fastio."
So the Teensy library may or may not have anything to do with USB communications or bootloaders.
The real experts in this field are PxT and lwalkera.
Postby pomonabill221 » 2014-Jan-Wed-15-Jan
Thank You Jay for your response! Yes that makes sense since teensy isn't used for anything else.
In my looking around, I did see at least the pins.h library and definition, so that makes sense.
It did confuse me as to why all three packages were installed when all that we use is the arduino and flip.
I know that since the experts do mention some steps, some of us that haven't done much of this before (ME) are confused when the info is kinda scattered... I have bounced around several threads trying to put it together and my paranoia of "just try it" keeps me from trying it since I know that it is all too easy to brick things if not done correctly!
There is great info here, and tons of great help... just need to see if it can be put in one place with a little more detail.
(This is NOT a rant/complaint (sort of)/whinning... so please don't take it that way.) I am just trying to get my info straight and complete.
Thanks!
PBplus V2 kit.
pomonabill221
Postby RetireeJay » 2014-Jan-Wed-15-Jan
PBplus V2 kit.
pomonabill221
Postby Hoverhead » 2014-Jan-Tue-01-Jan
Hoverhead
Postby Hoverhead » 2014-Jan-Tue-19-Jan
Hoverhead
Postby PxT » 2014-Jan-Wed-01-Jan
Postby Nickies08 » 2014-Feb-Wed-21-Feb
I can't get my drivers to install. I get this warning every time I go to device manager and try to update the driver:Image
I use to have no issue getting the Arduino to work on my Makerfarm Printrboard but now that I installed my new Printrbot Printrboard, I cannot get either Amtel Flip or Arduino to work due to the lack of USB drivers
Printrbot Plus V2.0
Aluminum bearing blocks
Aluminum Build Plate
Robotdigg custom Nema 17 motors with 500mm T8*8 Acme Rods on Z-axis (19" of print height)
Wire extensions to accommodate extra build height
GT2 Belts and Pulleys
Nickies08
Postby RetireeJay » 2014-Feb-Wed-21-Feb
I explain how to install the driver for FLIP (used to flash the program) in the wiki article pointed to by this post: viewtopic.php?f=22&t=6257
The procedure for installing the "teensy" driver for use by Repetier and Pronterface is written up in the Getting Started Guide on Printrbot's web site.
Postby Nickies08 » 2014-Feb-Thu-13-Feb
I did the step of going into device manager, selecting the USB device and telling it to install the driver from the Flip directory. That warning I get is the result. I even have a secondary set of drivers in another folder which I got from AVS freaks but I get the same result. I don't know how to overcome "the directory name is invalid"
Printrbot Plus V2.0
Nickies08
Postby RetireeJay » 2014-Feb-Thu-13-Feb
Return to Hack talk
