CL1 wrote:Just want to throw something out there to perhaps watch for. At the PrintrBoard Github, I see a note from Laine something to the effect of a revision reversing some jumper's polarity. If this is the programming jumper, it would affect your instructions here. Not now, but whenever that rev of PBd is shipped.
May 03, 2012 Make resonator pad larger to accomodate both available pacakages, and change polarity of BOOT jumper
175eccfdd2 Browse code
lwalkera authored 25 days ago
jr57k wrote:Stupid question... what firmware is on the board as shipped. For some reason I assumed Marlin, but I haven't confirmed it... That's what I'm slicing against so it must be.
Jason_Read wrote:I find the idea of flashing the firmware utterly terrifying, what advantage will it give and do I really need to do it at this point?
PxT wrote:Brook asked me to write a document on how to get started with compiling and uploading a new firmware version, for those who are interested. I wrote the doc and sent it to him but he has not responded in a couple of weeks. Rather than wait any longer for him to post it on his website I am going to put the link here. If he does respond at some point then I will update this post with the most up-to-date link.
Printrbot Firmware.pdf
http://dl.dropbox.com/u/68081994/printr ... rmware.pdf
Please let me know if any questions or feedback.
extent wrote:Hold shift while you hit compile and it will spit out the location of the HEX file when it's done in v.23 and earlier, I think that verbose output was moved into a checkbox option in 1.0 but I don't use that version so I'm not entirely sure.
PxT wrote:When you connect to the printer for the first time after it has been powered up you should see it say "Connected" along with the firmware version and some other text in the console area on the right side. I'm not near my printer right now so I can't provide a screenshot. Maybe someone else can help with that.
Macintosh users:
• Download the customized Arduino software from http://printrbot.com/support/instructions-guides/ and copy it to your /Applications folder.
Open the Arduino preferences (⌘,) and turn on the checkbox to enable “verbose output during compilation”. Close the preferences window.
#if defined(__AVR_AT90USB1286__)||defined(__AVR_AT90USB1287__)
#define MYSERIAL Serial
#else
#define MYSERIAL MSerial
#endif
JasperJ wrote:Macintosh users:
So that one appears to have been removed.
RetireeJay wrote:Call me timid, or call me paranoid, but I wanted to make a copy of the firmware that's already in my Plus before I erased it and re-flashed it with something new.
RetireeJay wrote:When programming with a new version of Marlin, is the bootloader automatically included in the rewrite of memory, or is it somehow in a "safe" zone that doesn't get touched?
sudo apt-get install flex byacc bison gcc
sudo apt-get install avrdude binutils-avr gcc-avr avr-libc gdb-avr
sudo apt-get install dfu-programmer
sudo apt-get remove --purge modemmanager
