Firmware on Simple Pro
Code hacking talk
Postby goofdad » 2017-Nov-Thu-21-Nov
I just acquired a Simple Pro. I'm quite happy with the build quality and the print quality ... however I'm not particularly fond of the cloud interface and the front panel interface. Also, the firmware seems to be missing key elements. Ex: I tried issuing an M501 from octoprint produces an Alarm of invalid gcode and a disconnect.
Is there a way to flash a straight Marlin firmware? It would need to support that beautiful graphical touch screen?
I've searched the forum for "Simple Pro" and "Pro firmware" ... not sure what else to search for :)
Thanks in adavance.
goofdad
Re: Firmware on Simple Pro
Postby cbxbiker61 » 2017-Nov-Fri-00-Nov
The G2 (arm based) board on the newer PrintrBots does not use Marlin. When I looked at it earlier this year, I found that the PrintrBoard G2 configuration is in the main firmware source tree (i forgot the firmware's name but you can google it). You should be able to download that and hack it.
cbxbiker61
Postby brookdrumm » 2018-Feb-Mon-18-Feb
The G2 does have an onboard interpreter to use marlin. So you can use cura, repetier, printrhub.... but not simolify3d yet... still tracking that one down
Beook
brookdrumm
PBHQ Official
To put a fine point on it: the g2 supports regular gcode, but to set current, and do some of the setup stuff, you will need to use json
It is similar to using codes, but is new so might seem foreign.
I will get a list on our website of what commands do what. These are on the g2core wiki, btw:
[url]https://github.com/synthetos/g2/wiki/What-is-g2core
[/url]
The benefit is one board/firmware that does Cnc and 3dprinting. I realize some don’t see the benefit but marlin is not the best code.
There is a lot of power in that tinyg code, so it’s worth considering.
Brook
brookdrumm
PBHQ Official
Return to Hack talk
