Printrbot Talk Forum • View topic - Arduino IDE versions and compile size
Code hacking talk
Postby revnull » 2016-Mar-Thu-15-Mar
revnull
Re: Arduino IDE versions and compile size
Postby RetireeJay » 2016-Mar-Thu-17-Mar
Since you are obviously keen on collecting data, you might want to compare the hex size that you get if you use PlatformIO as your compiler. viewtopic.php?f=22&t=10160. I didn't try multiple generations of Arduino, but I did see a fairly substantial reduction in hex size when using PlatformIO. (I didn't record exactly how much :( )
Postby thawkins » 2016-Mar-Thu-19-Mar
Postby revnull » 2016-Mar-Thu-22-Mar
Added PlatformIO numbers as requested.
One more bump in the road to full graphic LDC goodness. Since my printrboard is based on the teensylu, it looks like I have less program space than I thought.
teensylu.upload.maximum_size=122880
I assume the rest of the space is taken by the DFU bootloader? Looks like I'll have to dig deeper to find things to remove. Anyone have any luck removing SD card support? I don't use it, and thanks to octoprint, I don't need it.
revnull
Postby Mooselake » 2016-Mar-Fri-09-Mar
The Arduino 1.6.7/8 and platformIO numbers are pretty close. Iirc pIO's biggest advantage was smaller size from better use of the linker removing redundant library copies. Maybe a bit of competition was good?
Be interesting to see if there's any difference in maximum or smoother step rates, or reliability, but that takes test gear most if us don't have.
Return to Hack talk
