E3D install: Error message when compiling firmware file
Code hacking talk
Postby jdb257 » 2015-Jul-Tue-02-Jul
Hey All,
I've just installed an E3D hot end on my LC+ and I have been following this guide(http://thisoldspoon.blogspot.com/2015/0 ... -os-x.html) and a few others that were necesary to setup teensyduino. I am to the firmware section and I have edited the line of code to change the Temp_Sensor setting for the new thermistor, that wasn't a problem. Once I saved the file, and tried to compile it I received an error message that I have no clue what it means and was hoping someone could help me out. Any info would be appreciated! my guess is it is something I have overlooked somehwere along the way when setting up the Arduino IDE/Teensyduino software. Thanks for your help!
jdb257
Re: E3D install: Error message when compiling firmware file
Postby PxT » 2015-Jul-Tue-10-Jul
It looks like something is wrong with your Arduino installation. Try to reinstall it like so (adapted from RetireeJay's writeup on the wiki which is currently unavailable):
  • Download Arduino 1.05 From https://www.arduino.cc/en/Main/OldSoftw ... ases#1.0.x Follow the installation instructions. Note the address where the program is stored. This is probably
    C:\\Program Files(x86)\Arduino
    (If it’s different, then apply the appropriate changes to directories mentioned below.)
    NOTE: This IS done with a Windows “Installer” so you will get your desktop and Start menu icons. You still may need to set up file associations.
  • Download Teensyduino from the “download and install” link at http://www.pjrc.com/teensy/teensyduino.html Follow the installation instructions, referring to the Arduino program directory if asked. (Note: You MUST have the Arduino system installed first.) You will be asked if you want to install a USB driver; it’s safe to say yes to this. You will also be asked if you want to install any of several libraries; do NOT install any of them. When you tell the installation to proceed, it will take quite a long time to complete the installation; be patient.
  • Download http://blog.lincomatic.com/wp-content/u ... 286txt.zip Unzip the file and you will find three files inside, “boards.txt,” “boards.txt.nopjrc,” and “programmers.txt.” Copy the files from this download into the
    C:\\Program Files(x86)/Arduino/hardware/teensy
    directory, overwriting the original "boards.txt"
  • Rename the directory
    c:\Program Files(x86)\Arduino\hardware\teensy\cores\teensy
    to
    c:\Program Files(x86)\Arduino\hardware\teensy\cores\at90usb1286.
    You should now have a working Arduino IDE which can be used to compile code for the Printrboard.
Note that the above instructions are for Arduino 1.0.5. You might be able to adapt them to newer releases, but 1.0.5 is known to work so I would start with that.
Re: E3D intsall: Error message when compling firmware file
Postby jdb257 » 2015-Jul-Tue-10-Jul
thanks for the feedback! I will try that and hope for the best. I noticed I was getting the same errors with all files when compiling so my guess is a reinstall might do the trick as I could have some folders not in the right directory or something similar.
jdb257
Postby RetireeJay » 2015-Jul-Tue-10-Jul
Are you on a Windows or a Mac?
I've posted the raw text file of my Wiki article about doing a Firmware Upgrade on a Windows computer as an attached RTF file here.
Postby jdb257 » 2015-Jul-Tue-14-Jul
Yes, I am on a PC.
Just downloaded the attachment you provided in your writeup and the instructions are pretty much identical to what was posted previously, no?
Here is what I've done so far...I was previously using Arduino 1.6.4 and tried 1.6.5-r2 and got the same results. Then I went back to 1.0.5, which is what RetireeJay's writeup is based on and when I ran Teensyduino, it wouldn't recognize the directory in Program Files that I installed the Arduino software...hmm.. I tried again, same results. Then I noticed on the Teensyduino 1.24 installation exe that the earliest compatible version of the IDE that it is compatible with is 1.0.6. so now I will retry with that version...
might be easier to just buy the thermister for the Ubis :D
jdb257
Postby jdb257 » 2015-Jul-Tue-15-Jul
compile success! worked without a hitch on 1.0.6 as far as I can tell - Now i will follow the steps to flash the file.
jdb257
Return to Hack talk
