Printrbot Talk Forum • View topic - (Another) Poor Man's Heated Bed
PostPosted: 2015-Jun-Tue-17-Jun
by ktfergus
First of all, my apologies to cacb for re-purposing his , but it’s pretty much what I envisioned naming this thread when I first started looking into alternate means to head a bed.
I’ve been happily printing PLA over the last few months, but now that I have a large project out of the way, I want to experiment with ABS and other more exotic filaments. At some point in the future I will definitely invest in a conventional heated bed, but until then I wanted to find something that was (A) inexpensive, (B) didn’t require purchasing an additional power supply or (C) didn’t involve soldering or extra wiring. Ideally, I wanted a heat source I could simply plug into an outlet to warm my bed. At this point, I’ll gladly sacrifice temperature adjustment for simplicity.
I looked exhaustively all over Amazon and eBay and finally stumbled upon for cars and other vehicles.
Those of you living in more northerly climes are probably all-too familiar with them, but living on the Central Coast of California, I had no idea these things even existed. (My family lived in Northern Utah until I was eight and I do remember having to plug in the car on cold winter nights, but at the time I thought that was to keep the water in the radiator from freezing).
There are a number of different sized pads each with varying wattages. My printer bed is 150mm x 240mm, so I opted for the version. I decided to use aluminum for the bed to aid even, quicker heat distribution and picked up a .125” thick sheet 6” x 12” off of eBay. I attached a thermocouple probe between the heat pad and the Al sheet to act as my thermistor. I looked into several insulation options and found a while searching Amazon which is fairly cheap & I could easily cut it to size with scissors. I then sandwiched the battery heat pad, the felt pad and two layers of aluminum foil between the aluminum sheet and a sheet of black ABS I had lying around (I wanted to ensure the PLA spacers I printed to enlarge my print bed wouldn’t be affected by the heat).
Here’s the whole thing assembled.
I’m sacrificing about 1” in the z axis, but up to this point I have yet to print anything over 5” high anyway.
I plugged in the heat pad & waited to see just how warm the Al sheet would get. I was pleasantly surprised to see just how effective the set up is, here's a plot of bed temp over time:
The heat pad tops out at 120C, just the right temp for ABS! Of course, the real test would be getting an actual ABS print to stick. I loaded up a roll of Hatchbox black ABS, plugged in the heat pad & set the hotend to 230C.
Here's the first print in action, with the temp readout:
Here's the finished part:
And here are some tiny gears:
I'm super happy with how everything has turned out. I'm starting out small and over the next few days I'll see if I can get larger prints to adhere, as well.
I can't wait to try Bridge Nylon next.
-Kelly
Re: (Another) Poor Man's Heated Bed
PostPosted: 2015-Jun-Wed-05-Jun
by cacb
Very cool .... eehhh hot :-) No need for apologies.
I like the unconventional ideas, and sometimes they do work quite well. This looks like a good example! Since this is a poor man's solution, how much did you save compared to the printrbot heated bed upgrade?
As you say, you don't have automatic temperature control this way, but it is still an excellent idea. I use the standard heated bed for PLA also, but 120C is a bit too hot for PLA, so your solution looks like ABS only.
I guess it is possible to add temperature control via e.g. a raspberry PI, but of course then the complexity increases and you might then be better off with the standard printrbot solution.
It would be interesting to hear more as you gain experience with this setup!
PostPosted: 2015-Jun-Wed-06-Jun
by RetireeJay
If you are very patient, you can probably control the temperature fairly well by various means of throttling the 110VAC input to the heater. A Variac is one possibility, but that's fairly bulky and expensive. You might be able to use an "infinite" control switch from an electric stove or hotplate: these work by switching the current on and off every few seconds, and they are smaller and less expensive than Variacs. The control will still be "open loop" - you set the percent power manually - but it's better than no control at all.
PostPosted: 2015-Jun-Wed-07-Jun
by thawkins
PostPosted: 2015-Jun-Wed-10-Jun
by Mooselake
If you've got room you can add one of or . I use a 50C NO version to control the wood to gas switchover on my heating system, so far (at least in that application) it works just fine, and I've got a lot of spares...
There's adjustable ones if you want to search for them, but they're quite a bit bulkier. EBay is full of cheap digital PID controllers that will give you better temp control, iirc my 120V version was somewhere around $20 with an SSR and sensor.
PostPosted: 2015-Jun-Wed-12-Jun
by ktfergus
PostPosted: 2015-Jun-Wed-14-Jun
by RetireeJay
PostPosted: 2015-Jun-Wed-15-Jun
by ktfergus
PostPosted: 2015-Jun-Wed-16-Jun
by cacb
PostPosted: 2015-Jun-Wed-20-Jun
by frankv
Try taking the felt away from underneath.
Or just buy another heating pad with a bit less power... if 60W gets you 120 degrees, try the 50W one at $19.99?
by thawkins
PostPosted: 2015-Jun-Sat-22-Jun
by ktfergus
@thawkins: thanks for the link, I'll pick one up the next time I place an order from Amazon. That'll save some desk space; I might even print out a mount for the printer.
Speaking of Amazon orders, I received the yesterday, plugged the heat pad into it & started doing some tests. Sure enough, with the slider at around 50% the bed temp leveled off at approximately 65C. I loaded some Hatchbox silver PLA into the printer and tried a long print (aprox 170mm) which used to curl on my old unheated aluminum bed. Here are the results:
It printed out fine, no curl. I've been getting great results printing PLA on my unheated PolyCarb bed, but it looks like with this set up I can print both PLA & ABS on the aluminum; I'm a malanky bit sad to retire the PC bed, tho.
Here's a pic of the bed temp & the dimmer setting for the PLA print:
The only downside to the dimmer at this point is that it limits the bed temp to around 105C when the slider is at 100%. I've completed several sucessful small ABS prints at this bed temp, however, & if I run into problems in the future I can always remove the dimmer when printing ABS.
Meanwhile, I'm still getting the hang of printing with ABS. Here's a larger print (aprox 100mm x 100mm, 2hr, 20min print time) that I completed before installing the dimmer plug:
Bed Temp averaged 113C & it had no problems sticking to the bed. I haven't strayed too far from the initial Simple settings, but here are several changes I've had success with using the Hatchbox black ABS:
Layer height: 0.4mm
First layer height: 0.35mm
extruder multiplier: .92
Under "advanced" I lowered the first layer from 200% to 175%; 200% has worked well for PLA but with ABS it seemed to be over extruding, and left little globs of material all over the first few layers which interfered with the hotend.
In the coming week, I plan to try Bridge Nylon & Ninjaflex, both of which I've been dying to use for several projects.
From what I've read, Ninja prints well at 215C even on an unheated bed. I'm going to try 215C and a bed temp of 50C.
I've also read that Bridge nylon needs higher hotend temps, aprox 245C. I'm going to try 245C (if the ubis will let me) and a bed temp of 50C, as well.
Wish me luck...
