Printrbot Talk Forum • View topic - Threaded rod stabilization
Postby Thekaduu » 2014-Jan-Fri-15-Jan
Mainly RetireeJay and hopefully others:
What's the measurements of your brass treaded rod and where did you get it?
I have a PB+ v2.1 and am trying to stabilize the existing threaded rod by making a part for the top of the 12mm and threaded rod with bearing. I also read here that having an imperial size threaded rod and printing in mm could cause problem with certain layer heights.
PB+ v2.1 has 3/8" threaded rod. I have no information on what the pitch. Where can I get this information?
Do you all think it is better to have metric threaded rod? What parameters need to be changed other than z-calibration (steps per mm)?
Thank you for your time.
Thekaduu
Re: Threaded rod stabilization
Postby Lemm » 2014-Jan-Fri-15-Jan
using a metric rod is better for calculating the correct steps you can use, but it's not impossible to get a really good result with an imperial rod (jay showed it in an other thread)
This calculator helps you to find a rod or the correct layer height for your rod
http://calculator.josefprusa.cz/
for your 3/8" threaded rod you have a pitch of 1,337mm. Layer heights of 0.3mm should work well
Printrbot Jr #11045
ACME TR10x2 Z Rod
Printrbot Jr v1 -> v2 upgrade
Lemm
Postby Thekaduu » 2014-Jan-Fri-16-Jan
I have been getting OK results with 0.3 mm layer height. I like the site but it does not have the 3/8" threaded rod :/... Oh well. I can use the site if I end up changing the threaded rod.
So, the only think I need to change when I change size of the threaded rod is the steps per mm then?
Thank you Lemm.
Thekaduu
Postby Lemm » 2014-Jan-Fri-16-Jan
I found some different informations about the 3/8" threaded rod pitch, therefore maybe somebody with 3/8 in use can confirm this or correct me when I talked shit :D
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby RetireeJay » 2014-Jan-Fri-17-Jan
I'm a little surprised that you have 3/8" rods. I thought that Printrbot was using 5/16" - 18 threaded rod until they switched over to ACME threaded rod. The 5/16 - 18 threaded rod has 18 turns per inch. It's best to do your calculation of Z step height by starting with the native units. I wonder a little where Lemm got his information that 3/8 rod has 1.337mm per turn; that comes out to 19 turns per inch after allowing for rounding error - which seems strange to me. According to Wikipedia the pitch of a standard 3/8" screw is 16 turns per inch, not 19. A 3/8" Acme rod will have only 12 turns per inch.
In any event, if you look at this post viewtopic.php?f=21&t=5983, you'll see that having Imperial threaded rods does not hurt the ability to get smooth walls.
Apparently some early versions of RepRap printers used the threaded rod both to GUIDE the moving carriage and to LIFT it. So if the threaded rod was not perfectly straight and if it was not constrained top and bottom then the carriage would be moving around laterally as it lifted. However, on Printrbots we have the nice smooth rods to perform the guiding function, and the threaded rod only provides the lift. So we have much less problem with imperfect threaded rods and virtually no need for securing the rods at the top - at least that's my experience.
Postby Thekaduu » 2014-Jan-Fri-20-Jan
Thanks... I double checked and it is 3/8". I'll take your word for the good job that the smooth rods do. I guess my motor to threaded rod coupler (wood) is not straight and the rod wobbling as it is coming up. I found some parametric coupler in thingiverse () that I can try to make it not wobble then. This just to ease my mind. I read the topic you posted which says it does not make difference in the print quality if rod wobbles a little bit.
But why brass rods? Brass is softer than steel, therefore, it should wear sooner...
Thekaduu
Postby RetireeJay » 2014-Jan-Fri-22-Jan
Ordinary steel threaded rod from the hardware store is not made for motion control; it's made for holding things together. Low-precision, high-load things, like in building construction, or repairing agricultural equipment etc. It's zinc-plated, so it's texture is rough. Generally brass threaded rod is made to tighter tolerances - or so I'm told; I can't cite industry documents to prove this - and it's smoother. When you are turning the rods with stepper motors using microstepping, it's better to have consistent low friction than rough and inconsistent friction.
A little wear is a good thing - the threads become even smoother. It looks like it will be decades of use before my brass rods are so worn that they need replacement. :)
Postby Nickies08 » 2014-Jan-Sat-00-Jan
Have you used the method in the setup guide to properly align your threaded rods to the motors? I overlooked that step originally and later found it. I would have to occasionally re-do the alignment on my Plus V2 because of accidental bumps and stuff or if a part failed and my hotend smashed into the part. Raise your carriage almost to the top of the threaded rods and undo the coupling on one motor. The rod will then hang down and sit over the motor shaft. Reinstall the coupler, ensuring not to move the threaded rod out of place and then repeat the same process on the other side. Home your z axis and watch the movement of your threaded rods, they should be a LOT MORE stable. If not, remove the rods from your printer one at a time and roll them on a flat surface. They should roll smoothly and not have any wobble or raised spots. If they wobble or have raised spots, the rods themselves are faulty.
Printrbot Plus V2.0
Aluminum bearing blocks
Aluminum Build Plate
GT2 Belts and Pulleys
Nickies08
Postby Thekaduu » 2014-Jan-Sat-03-Jan
Thanks for the brass info RetireeJay.
Nikies08: I assembled the printrbot exactly as it was instructed. I just see the threaded rod wobble just a little bit, that's all. Being the person that I am, it is unacceptable :o.
Joking aside, I think the amount of wobble is fine like RetireeJay said. It's just me.
I build 2 set of the threaded rod to motor coupler and installed it already. It minimized the wobble a little bit. I also ordered 2 of 3/8" ID x 7/8" OD bearing.
I will use them to hold the barely wobbling threaded rod at the top. I already designed the part and just build one; it literally finished as I was typing this.
Attached will be the part.
Thank you all again for your comments and valuable information.
Thekaduu
Postby Lemm » 2014-Jan-Sat-05-Jan
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby RetireeJay » 2014-Jan-Sat-09-Jan
:o What?!? There's information on the Internet that's wrong?!? Who would have thought? :D
Postby Lemm » 2014-Jan-Sat-16-Jan
I don't believe the information is wrong, I just think I had misunderstood it ;)
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby RetireeJay » 2014-Jan-Sat-18-Jan
Well, I don't speak German, but usually I can read tables.
It SEEMS like the next-to-last column would be giving thread per inch (it has something to do with inches, that's for sure).
What is it really?
Postby Thekaduu » 2014-Jan-Sat-21-Jan
If I want to purchase a brass threaded rod and nut, what would be the specs of both?
I thin the rod is 3/8" 19 thread per inch with 1.337 pitch... How about the nut?
Also, how about M8 rod and nut specs? If I switch to metric rod, what parameters will need to be changed?
Thekaduu
Postby ei8htohms » 2014-Jan-Sun-03-Jan
Have you been reading the same thread as I've been reading? There aren't really 19 TPI rods around (or please find us another reference to such a thing).
Get M5 or M6 rods in brass with stainless steel nuts (or vice versa, you don't want the rods and nuts to be the same material). Or better yet, get proper trapezoidal threaded rods (and nuts).
Printrbot GO v.1 - steampunk
Igus DryLin nuts
PB LCD/encoder
GT2 belts
Twin 30mm fans
ei8htohms
Postby Lemm » 2014-Jan-Sun-03-Jan
The informations are correct but they are for a British Standard Pipe that was my mistake. Not for a threaded rod but for a water pipe :D.
And for that 3/8" BSP the pitch is 1.337mm 19tpi.
The pitch for a M8 rod is 1.25mm
http://de.wikipedia.org/wiki/Metrisches_ISO-Gewinde
You can calculate your steps with the prusa calculator
Printrbot Jr #11045
ACME TR10x2 Z Rod
Lemm
Postby wd5gnr » 2014-Jan-Mon-08-Jan
The 2.1 has PB's ACME rod which is 3/8" and the correct Z value for it is 2015.75.
Al Williams
Twitter: @awce_com
wd5gnr
Postby Thekaduu » 2014-Jan-Thu-20-Jan
Thekaduu
Postby Jon Lawrence » 2014-Jan-Fri-13-Jan
Jon Lawrence
Calibration mode.
Some calculations of various threads, long hand, if anybody is interested:
Jon Lawrence
Calibration mode.
Postby Thekaduu » 2014-Feb-Sun-00-Feb
Thanks Jon. You seem to have book on that one :) i will set the z at 1511.81 to be exact. Also, if I chose to change the rod, I now have enough information to get the corrct one.
Thanks all for your help in this discussion.
Thekaduu
Postby wd5gnr » 2014-Feb-Wed-17-Feb
Interesting. I have 3 different sets of rods... maybe these aren't the ones from PB ;-)
Al Williams
Twitter: @awce_com
wd5gnr
