Printrbot Talk Forum • View topic - Anyone tried auto leveling?
Postby nepaholic » 2013-Dec-Sun-14-Dec
Hi
I have seen that some people use a auto leveling modification where a servo pull out a probe and measure the bed leveling)on their printers and wondering if this is possible to do with the printrboard to?!
Would be nice if this is possible. The firmware wouldn't be the biggest issue I guess. Just need some connection to the board.
Cheers
Jens
nepaholic
Re: Anyone tried auto leveling?
Postby Nickies08 » 2013-Dec-Sun-17-Dec
There is already a software version available through matterform. There is a forum discussion on it already. You should be able to find it by searching auto leveling or matterform. I wanted to share the link but tapatalk won't let me paste the link
Printrbot Plus V2.0
Aluminum bearing blocks
Aluminum Build Plate
Robotdigg custom Nema 17 motors with 500mm T8*8 Acme Rods on Z-axis (19" of print height)
Wire extensions to accommodate extra build height
GT2 Belts and Pulleys
Nickies08
Postby REPRAP SQUAD » 2013-Dec-Sun-17-Dec
Matterhackers has a software download for auto leveling. There is an open spot on the Printrboard that could be used. Next to your endstop plugs you will see an open plug labeled e-stop. If someone wanted to write the firmware it could easily be done. You also can easily do it without adding a servo. The goal should be the least amount of mods to add it on.
Postby thawkins » 2013-Dec-Sun-18-Dec
Postby REPRAP SQUAD » 2013-Dec-Sun-21-Dec
Running my nozzle into my platform a few hundred if not thousands of time will put some wear and tare on the hotend. I would rather set it up with an endswitch as a probe using a magnet to fold open and close the switch. Gcode additives would be simple enough
Postby nepaholic » 2013-Dec-Mon-03-Dec
Hi
Well I personally don't like a software solution for this because my printer I operated with a panelolu2.
Reprap squad: do you know what output the endstops have? If I read right the servo need 5 V output and the probe is wired together with the z endstop?!
I read a lot of people use this on their ramps board but I dot find a good information about this board. This board seems very complicated though
Cheers
Jens
nepaholic
Postby thawkins » 2013-Dec-Mon-04-Dec
Postby nepaholic » 2013-Dec-Mon-05-Dec
Maybe just wire 5v to a atx power supply and the pwn and ground wore to the e endstop?
nepaholic
Postby nepaholic » 2014-Jan-Mon-12-Jan
I finally have auto bed leveling running.
Wow this is amazing, time to say goodby to manually leveling the bed :)
http://youtu.be/M3A5f316BMs
nepaholic
Postby Lemm » 2014-Jan-Mon-12-Jan
looks good, what about a howto ? ;)
Printrbot Jr #11045
ACME TR10x2 Z Rod
Printrbot Jr v1 -> v2 upgrade
Lemm
Thanks. Well I hooked the servo signal pin to the exp2 header with the number 11 (if you are in front of the board the pin in the upper left) and took grnd and 5v from the atx.
The endstop is in series with the z endstop.
The only problem I have now is that if I have my LCD enabled it won't compile :(
nepaholic
Postby pomonabill221 » 2014-Jan-Mon-15-Jan
PBplus V2 kit.
* NOW with AUTOLEVEL!!!!
pomonabill221
Postby nepaholic » 2014-Jan-Mon-16-Jan
nepaholic
Postby pomonabill221 » 2014-Jan-Mon-16-Jan
I have a PBlc+ with the PB printerboard rev.D
I guess I am confused as according to the readme included with the firmware from Eric, he lists many other features like temperature features, SD card features, many other items that don't seem to apply to auto leveling.
Also, he states to download the Arduino IDE and the Marlin firmware. Then run the IDE and select the Arduino Mega 2560... my pb board has a 90usb1286 processor on it.
And then use \*define statements... where does this get done.
Is this for the PB printer at all or another printer?
Sorry for my ignorance, but I would like to try this out, but don't want to brick my printer so I need to know if I should follow the readme instructions.
PBplus V2 kit.
pomonabill221
Hi I'm not at home right now so I don't have the link to the firmware I used. Google it and you find it. Then scroll down on github. He explains very well how to use it.
Have you ever flashed your firmware?
There might be pre installed versions of the arduino app here on the forums.
When you open the firmware you can choose what board you have like ramps or printrboard.
Then you have to configure everything in the configuration.h file and write a few lines in the pins.h and you are ready to go.
nepaholic
Postby RetireeJay » 2014-Jan-Mon-16-Jan
Postby gmh39 » 2014-Jan-Mon-17-Jan
Would the auto-level need to run before every print?
Or is it something that we can use when we just need to re-level our bots? Like a probe that clips on/off and the auto-level feature stores the values.
gmh39
Postby nepaholic » 2014-Jan-Mon-17-Jan
You have to run it before every print. But it is no problem because you have it in your gcode. Just install it once and forget it :)
nepaholic
Postby gmh39 » 2014-Jan-Mon-18-Jan
True. But my point is that then you need a servo motor which adds more weight.
What I was considering is something that clips on, swings up and down, and secures at top and bottom with magnets. Then when you need to level you just flip it down, run the leveling code, flip it back up.
gmh39
Postby nepaholic » 2014-Jan-Mon-18-Jan
That's a nice idea. I also had this idea but thrown it because I'm to lazy ;) the servo is nearly no weight at all. I guess it have about 10g
For me it was faster to design a simple servo holder that can be attached to the wade extruder.
nepaholic
Postby thawkins » 2014-Jan-Mon-19-Jan
Postby REPRAP SQUAD » 2014-Jan-Mon-21-Jan
I agree with Ya and it can he designed to fit on various bots a lot easier using that method.
Postby thawkins » 2014-Jan-Mon-21-Jan
Postby RetireeJay » 2014-Jan-Mon-21-Jan
Postby nepaholic » 2014-Jan-Mon-22-Jan
Only a arm would be better and easier to do because you only have to install the endstop. I agree with that.
Jay you have to edit the firmware to set the offset.
nepaholic
Postby pomonabill221 » 2014-Jan-Mon-22-Jan
PBplus V2 kit.
pomonabill221
Postby thawkins » 2014-Jan-Mon-22-Jan
Postby gmh39 » 2014-Jan-Tue-10-Jan
I think you are underestimating the durability of the lever arm on the microswitches. They would act in a similar fashion as spring, so you would need to puish them past a certain point for them to be permanently deformed. If you are that worried about it, then you can always just use a microswitch without the lever arm.
gmh39
Postby RetireeJay » 2014-Jan-Tue-11-Jan
Postby KDog » 2014-Jan-Tue-13-Jan
I'm really intrigued by this topic. Check out the video by the smartrap guy: http://www.youtube.com/watch?v=ZSmtCz-WMKo
He seems to have it working awesomely!
Printrbot Metal Simple
KDog
Postby MegaMoonMan » 2014-Jan-Tue-13-Jan
I designed and built a Z endstop that utilized a thin pressure sensor on the bed at the home corner that the hotend would touch. It worked great, but I upgraded my machine and didn't put it back on, since my bed never goes out of level anymore thanks to the upgrades. The key to a level bed is a SOLID bed.
MegaMoonMan
Postby nepaholic » 2014-Jan-Tue-16-Jan
Jay, I copy this from the marlin description
Next you need to define the Z endstop (probe) offset from hotend. My preferred method:
a) Make a small mark in the bed with a marker/felt-tip pen.
b) Place the hotend tip as exactly as possible on the mark, touching the bed. Raise the hotend 0.1mm (a regular paper thickness) and zero all axis (G92 X0 Y0 Z0);
d) Raise the hotend 10mm (or more) for probe clearance, lower the Z probe (Z-Endstop) with M401 and place it just on that mark by moving X, Y and Z;
e) Lower the Z in 0.1mm steps, with the probe always touching the mark (it may be necessary to adjust X and Y as well) until you hear the "click" meaning the mechanical endstop was trigged. You can confirm with M119;
f) Now you have the probe in the same place as your hotend tip was before. Perform a M114 and write down the values, for example: X:24.3 Y:-31.4 Z:5.1;
g) You can raise the z probe with M402 command;
h) Fill the defines bellow multiplying the values by "-1" (just change the signal)
#define X_PROBE_OFFSET_FROM_EXTRUDER -24.3
#define Y_PROBE_OFFSET_FROM_EXTRUDER 31.4
#define Z_PROBE_OFFSET_FROM_EXTRUDER -5.1
nepaholic
Postby pomonabill221 » 2014-Jan-Wed-02-Jan
And I am assuming that the defines mentioned go into the marlin.h file? Any particular location in the file or just near the end of the auto level section?
remember, Some of us are trying to do this correct, and sometimes the information is given in bits and pieces. I know we don't expect hand holding, but the location of these mods IS important for the firmware to operate correctly.
I just spent a few hours going through most of the *.h files (for my own curiosity) and found the autolevel section in marlin.h, but some of the other entries in the the other H files was interesting as well.....
Is there a way that a dedicated pin on the uP could be used for the probe rather than in series with the Z stop, and how would that be defined in firmware?
Not a biggie but might be nice.
Thanks...
PBplus V2 kit.
pomonabill221
Postby nepaholic » 2014-Jan-Wed-17-Jan
You have to edit the configuration.h file to get it working. If you want to use the e stop pins you have to define it in the pins.h and change the pin to 37
nepaholic
Postby pomonabill221 » 2014-Jan-Wed-18-Jan
GREAT! Thank you nepaholic for that info! Very helpful and I will give it a try.
Thanks!
PBplus V2 kit.
pomonabill221
So in pins.h it would look like this:
(this is the section for motherboard =8 and 81 the printrboard)
#else // Printrboard
#define X_STOP_PIN 35
#define Y_STOP_PIN 8
#define Z_STOP_PIN 36
#define E_STOP_PIN 37 //added to use e stop pin for auto level *******
#define TEMP_0_PIN 1 // Extruder / Analog pin numbering
#define TEMP_BED_PIN 0 // Bed / Analog pin numbering
#endif
PBplus V2 kit.
pomonabill221
Postby lwalkera » 2014-Jan-Wed-19-Jan
Laine Walker-Avina
lwalkera
Postby nepaholic » 2014-Jan-Wed-23-Jan
That's nice. Thanks for the info. I right now use the firmware from Eric but will check out yours ASAP
nepaholic
Postby thawkins » 2014-Jan-Mon-00-Jan
Just managed to score a OMRON EE-SPY402
Cute device, uses modulated ir to sense proximity, works on 5v to 24v, and has a driven output, in fact you can wire it up straight to the +5, gnd and input pins of the zstop conector, and it just works. I can read the stops with m119 and see it flipping back and forth. Only downside is that it is inverted. When the bed is within about 1cm of the end of the sensor it flips. And simulates a close rather than an open. However it should be eady to connect a reed relay to handle the inversion, it has a class b output which means it will drive a load between either rail.
It seems to be capable of detecting the bed within about 1 cm. It should be feasable to position it reasonably close to the nozzle with a bit of thermal insulation to stop it picking up radiated heat. Im thinking of a small aluminium bracket and mounting it on the opposite side to the hotend.
Its using modulated ir, there is a cheaper version spy302 that is not, but the modulation makes it insensative to ambient ir sources, and means the material its reflecting off is less of a factor. It has a small red led on tbe side so you can visably see when it trips, i have tried it on uncovered bed, covered with both masking tape and blue tape, and it seems to make no difference.
I paid 550peso for it here in philippines, which is about $12-13, expect it to be considerably cheaper in the us.
Im going to get it mounted and see if it works.
Postby pomonabill221 » 2014-Jan-Mon-01-Jan
PBplus V2 kit.
pomonabill221
PBplus V2 kit.
pomonabill221
Postby pomonabill221 » 2014-Jan-Mon-02-Jan
PBplus V2 kit.
pomonabill221
Postby thawkins » 2014-Jan-Mon-02-Jan
I must admit, im not using glass or aluminium, i can put a piece of al and glass on my bed and see what happens.
It seems to be accurate to about 0.005 mm, ie there is a position i can reach where moving z up or down by that amount causes it to flip.
Re pricing its a bit wierd, i got it for $12.5, i have seen it in one off for $16 in various places, but mouser lists it as $44 one off. Its an industrial device, probaly not designed for consumer electronics.
Im going to mount it properly, and hook it up to a 74LS04 TTL inverter so it can connect it direct to the zstop. And then see if i can use it first for accurate z homing. I can power both the sensor and the inverter off the zstop power.
If that works, i'll flash the bed leveling code and try it out. Will post video if it looks good.
Postby thawkins » 2014-Jan-Mon-09-Jan
Postby pomonabill221 » 2014-Jan-Mon-13-Jan
That's good news about the opto... did you try glass and Al?
BAD news about the firmware though!
My concern (question actually) is if the opto is being used in series with the Z limit switch, does the opto interfer with the Z switch when the opto is not being used?
Is the Z limit switch even USED at all??? I would imagine that since the autolevel is finding the points on the bed, the firmware would use that value for the Z position.
If not, while Z is homing, does the limit switch trip for home or does the opto trip first (since the two switches are in series, the first one would trip and tell the firmware that "I'm home").
I would rather use the Estop input on the board for the auto level sensor, and leave the Z stop sensor on a separate channel...
So the G code didn't start the autolevel and it didn't stop after it had done it's routine????
PBplus V2 kit.
pomonabill221
Postby nepaholic » 2014-Jan-Wed-08-Jan
So after some time I can say that I love this. The prints come out very nice but I still have some trouble with the marlin firmware and printrbot firmware and can't find what is wrong.
The print do not start centered on the bed. My probe has an offset of X33 Y-10 Z-3.60
When the print start the nozzle move to the right side of the bed and print there instead of the center.
I tried to change the offset and changed the values to X-33 Y10 and when I do it the print start on the left side of the bed.
If I change the values to X0 Y0 it start correct but this would give not correct measure.
The other issue I found with the printrbot firmware is if have the accurate bed leveling dissabled(so it do a 3 point measurement) the probe measure two points at the same place on the bed and the third correct.
So right now I only can print with accurate bed leveling (4point) but only print small objects due to the miss placement
I all ready reported this to Eric but didn't heard anything. I even searched the net about this but didn't found anyone who had the same problem.
Maybe my printrboard is the problem?
nepaholic
Postby thawkins » 2014-Jan-Wed-11-Jan
Postby nepaholic » 2014-Jan-Wed-13-Jan
Ok here it is:
G28 x0 y0
G28 z0
G29
nepaholic
Postby pomonabill221 » 2014-Jan-Wed-15-Jan
I am confused... (isn't hard these days).... Some have been using the autolevel with no problem, where others have had nothing BUT problems... Can we somehow try and see what the differences are?
Do we still need to use the Z endstop?
Where does it need to be set in relation to the autolevel sensing position (Z stop lower than autolevel/higher/just shorted out).
I am losing faith in this mod since all of the problems have surfaced.
This is what I have come up with... if not correct please someone explain:
During homing, the autolevel switch is not used and is swung out of the way, but still in the circuit (normally closed switch). The Z home switch opens when home.
During autolevel, the autolevel switch is swung down and used and should operate first BEFORE the Z home switch. The autolevel switch opens when touching bed and Z home switch is NOT operated (autolevel switch is lower than home switch so it operates first).
I did ask about changing the autolevel switch to the Estop port and I did get an answer, but I want to know how the firmware knows what pin/port to use as there doesn't seem to be a definition for that. The Zendstop will still have to be set IF it is still used, but my confusion is what does the Z endstop do when you have autolevel? Is my description correct?
PBplus V2 kit.
pomonabill221
Postby nepaholic » 2014-Jan-Wed-15-Jan
Hi
Well you do not need the old z endstop. I just use it in case something happens.
You have first to home all axes so the printer knows where to start. After that you do the auto leveling(g29). The printer use these values and write it in the storage somewhere.
It is important to not auto home after you have done the g29, because the values will be erased if you do.
The probe flips out during the g29 and that's why you have to write the offset in the firmware so the printer knows the location of the probe.
I right now work on a simple arm that can flip out without a servo. I use magnets for this and they are very strong.
Just didn't had the time to install it because the servo is working very well for me.
nepaholic
Postby thawkins » 2014-Jan-Wed-18-Jan
Postby pomonabill221 » 2014-Jan-Wed-19-Jan
PBplus V2 kit.
pomonabill221
Postby nepaholic » 2014-Jan-Thu-08-Jan
Hi
I got the bed leveling running now. So many times of flashing and debugging and at the end it was just a simple number that was wrong in the firmware.
I try to explain
When you setup your probe you have to set the offset of the probe.
The location of my probe is X+33mm on the left side of the extruder and Y-10mm.
Then you have to write the probing positions of the bed like: 30mm left, 100mm right, 15mm front, 120mm back in the firmware.
My left position was not right and if I do a easy math 33mm(the position of the probe)-30mm (where I wanted a probe position)= -3mm.
This means the extruder want travel to x -3mm. That's why I had all the problems. I changed the wanted position to +40mm and now it work awesome.
Sorry if I make you all headaches, but my English is not the best and I want to write as easy as possible.
@pomonabill
I don't no why you do not understand the principe of the bed leveling!?
Have you searched the net about it?
Let me try to explain again and forget this time the usual z endstop you have.
you want to start a new print and homing ONLY the X and the Y axis. Now the printer move the the endstops.
After that you have to start the auto bed leveling with G29.
Now the printer start to move to the locations you defined in the firmware, deploys the probe and measure the bed at each location( see the video I posted).
After that you get the measured values from the printer in pronterface or whatever software you use.
Then the printer start to print and use the measured values to compensate the print. You can see the z axis moving while printing.
The printer do not need a endstop longer, only the new probe. That's why you have to define the probe position in the firmware so the printer knows where the probe is and the nozzle.
Thawkins,
I have the codes in my start gcode and everything do automatic.
My start gcode is(sorry don't have all gcodes right now because I write on my mobile):
-Set bed temp
-set extruder temp
-g28 x0 y0 homes only the x and y axis
-g29 do the probing
-wait for extruder final temperature
-print
Hope you all understand now
You also can check this thread
http://forums.reprap.org/read.php?151,246132
nepaholic
Postby pomonabill221 » 2014-Jan-Thu-13-Jan
I just had to remove the content of my post.... it isn't necessary in this thread AND I cannot stand reading it (embarrassed actually!)...
PBplus V2 kit.
pomonabill221
Postby nepaholic » 2014-Jan-Thu-14-Jan
Umpf ähm ok.
I always said that I use my old endstop in case something's happen with my probe. I already mentioned it in the first posts.
If you also check post #13 you can clearly see how to get the auto leveling running in my start gcode.
There I wrote:g28 X0 Y0 followed by a g28 z0
If you think about what this gcode means you see that your printer do it every time you start a print.
nepaholic
And you don't have to be angry or something. Cool down. I try to explain everything as best as I can with my bad English and that sometimes might sound a little rough.
nepaholic
Postby pomonabill221 » 2014-Jan-Thu-15-Jan
(removed the nasty stuff... once again it wasn't necessary)**********
SO... I want to make SURE I UNDERSTAND...
1) the Z endstop is NOT used for ANYTHING other than a "safety". This COULD happen IF someone (like stupid me) were to hit "home all" in repeiter. The original Z switch would keep the extruder from crashing into the bed. This is the ONLY reason for the original Z switch.
2) the original Z switch, for instance, could be set so that the switch activates at, FOR INSTANCE, 5mm above the bed (THIS IS AN EXAMPLE ONLY AND IS FOR MY SHALLOW KNOWLEDGE... it MAY help others understand as well.. but I wouldn't count on it ). It isn't used for ANYTHING ELSE... no position/calibration/layer height/NOTHING BUT A SAFETY.
3) the autolevel switch could be set to activate at 10mm so you wouldn't get close to the original Z switch's operating point. When autolevel is de activated, it would NEVER touch the bed, and further, IF a home all axes (INCLUDING the Z axes... NOT normal though), the original Z switch would keep the extruder from crashing the bed.
4) the height (or Z offset) for the autolevel switch needs to be in the code so that the distance is compensated for, and the nozzle will be 10mm LOWER than when the autolevel switch operates. THIS IS AN EXAMPLE FOR CLARIFICATION... the offset for the original Z switch and the autolevel switch can be almost anything, BUT the autolevel switch MUST OPERATE HIGHER than the original Z switch.
Is this what is supposed to happen?
PBplus V2 kit.
pomonabill221
Postby RetireeJay » 2014-Jan-Thu-16-Jan
Pomonabill221,
May I humbly make a suggestion?
I worked for a company with headquarters in France and dealt with many French-speaking colleagues, many of whom wrote to me in broken English. And I sometimes I tried to write to them in French. What I learned from this experience is that it is very hard for a non-native speaker to express things with subtlety and nuance. So the best guideline is to give the other person the benefit of the doubt. If a statement could be interpreted as insulting, or it could be interpreted as simply factual - even if stated bluntly - just accept it without prejudice.
I really don't think nephaholic has been intentionally omitting information or saying things in a misleading way with the intention of making you frustrated. His intentions are good.
I understand the frustration with trying to tackle a technology that you don't feel comfortable with. For example, see my posts about trying to learn how to flash the firmware. It took me several rounds of back and forth with PxT until he finally realized exactly what part of the puzzle I was missing. viewtopic.php?f=22&t=6092#p39391. I guess I displayed a little frustration myself... :oops: But flaming isn't going to make the discussion any easier.
Postby pomonabill221 » 2014-Jan-Thu-21-Jan
That's what I like about you, Jay, you have the patience of a saint and offer great and sensible help and suggestions!
I appreciate your thoughts about my little rant and I agree with what you said... Thank You!
I know nephaholic is trying his best to offer his help and ideas the best he can, and I am trying to follow as best I can, and that is why I ask questions (maybe too many), and I get frustrated when I don't understand, and it seems like the other person is inferring that I am stupid and SEEMS like "he" is replying to me in a sarcastic manner.
I am just trying to get a clear picture of what the other person is doing.
Just another example...
I am a member of another forum (EEVBLOG) and the thread I am following and participating in is for the Flir E4 thermal camera which I have, and the wonderful mods to unlock the full abilities of these cameras which I have done.
There are a couple of people that have done a ton of work with the firmware mods, and I have also tried to contribute.
Now I know that you and I and I am sure there are many others know that IF a firmware mod is done incorrectly (even a slip of the keyboard by adding a space), would probably brick the device! Do I hear "voided warranty"??? What do you think Flir would say.... HA! $1000 please!
There was a question that I had asked about trying a temporary mod using telnt and I didn't understand the command syntax.
The response that I got was VERY sarcastic and VERY nasty.
After a reply about his unnecessary response and a inappropriate flag, he apologized through PM (NOT publicly), that he had mistaken me for someone else.... just shows that ya gotta pay attention when you write a reply.
Someone else did respond and kindly explained how the syntax is done, and I have been doing this ever since with no problem.
BTW... that thread is over 3338 posts long! It is called Flir E4 thermal imaging camera teardown... and NOW I can see how my beds are heating up!
The flaming was not my intent but I just wanted to point out where I was getting conflicting messages and I was feeling like my questions were not valid and I should have been able to figure things out myself... I REALLY do want this to work and I have come up with a probe myself (which if anyone is interested in, I can post pictures of), but I needed to know the particulars of the switches, why we don't use the old switch (except for an "emergency Z endstop"), and how to set it up.
That is why I posted my 4 point post... I wanted to make SURE that at least I understand. I also hope that this might help others as well.
I am not a G code genius so it isn't always clear to me what the different codes mean so I look them up.
I had also asked about "remapping" the E stop input and I saw how to assign a pin to the connector and posted a partial listing of the defines, but I also asked how the firmware knows to us the new pin, and never got a response, so this is still a mystery to me as I couldn't find the definition anywhere.
So, I do try and figure things out myself before asking because that is how I learn, and when I hit a roadblock, I ask questions. I didn't develop the mod., and I don't know what the intent of the mod is (the firmware implementation that is... I DO know what auto level is... there isn't a question about that), so rather than second guess something, I think it is better to ask.
It may seem simple for some, and the "developer", but for someone that is trying this cold turkey, there are some things that need to be said in detail.
Hopefully I have conveyed to nepaholic what part of MY puzzle that I am missing, and I hope that what I have listed is correct because that is what I have assumed.... IF it is wrong... PLEASE let me know! and if it is correct, also let me know.
Thanks again Jay for your insight!
PBplus V2 kit.
pomonabill221
Postby nepaholic » 2014-Jan-Fri-13-Jan
Thanks Jay for your kind words and thank you pomonabill for understanding.
It was indeed very misleading and my chosen words wasn't correct.
I write most time from my mobile and don't have access to all codes in the firmware.
nepaholic
Postby pomonabill221 » 2014-Jan-Fri-14-Jan
OK... I need to say something about my previous posts, and how off base it got. AND I need to be brief!
I am sorry that my frustration in trying to understand took over and I got rather nasty myself. I should NOT have passed this onto ANYONE, nepaholic, I apologize for jumping on you! I know you are trying very hard to help, and develop the code as well.
I know that when typing a post, the true emotions don't come through and ALOT of misplaced emotion and misunderstood thoughts can be expressed.
Also, the "language barrier" (which happens in ALL forums), sometimes is difficult, and that can lead to frustration also.
I do NOT know where all my "pissyness" and "flaming" came from... really I don't... (need to take a pill I guess.. yeah right).
Once again... to everyone here and nepaholic, I apologize for my "explosion".
NOW CAN WE GET ON WITH AUTOLEVELING!!!!
PBplus V2 kit.
pomonabill221
Postby nepaholic » 2014-Jan-Fri-15-Jan
No problem mate.
I will try to answer your questions as soon as I can.
About code. It is not from me. Some people have developed it and merged it to the marlin branch. I just tried to get it working on our bots.
Tough I have the original bot and things might be different on your newer models.
My probe arm and servo holder are designed for the original bot so it don't help you if you mount it.
But I work on a design that might help the other people and inspire to get it running on the simple,jr,LC,plus
I can upload the openscad code so you can make the necessary changes yourself.
It use only 4 magnet with the dimensions= 4mm diameter 5mm high. With this you can flip out the probe manually then probe the bed and flip it back manually. So you all do not need to buy servos and install it on the exp2 header.
About the printrbot firmware with bed leveling I had to make some changes to get it running. In this firmware it is defined to probe the bed in the center of the bed(+10 and -10mm) it didn't worked on my bot and I had to change the file.
I can post it if anyone is interested.
Cheers
Jens
nepaholic
Postby pomonabill221 » 2014-Jan-Fri-15-Jan
Well... yes it was a problem... FOR ME! I didn't like what I saw so I edited out the stuff that wasn't contributing to this thread, and was insulting to you (and everyone else probably!).
I,for one, appreciate what you have done to get this working! and thank you for your effort and sharing what you have done.
I am using a solenoid to lower and raise my probe, so I would like to use the exp2 output, but would need to change the duty cycle of the PWM to 100% (or close.. I can filter the ripple).
I am driving a power FET that will control the solenoid (diode clamped of course).
PBplus V2 kit.
pomonabill221
Postby KDog » 2014-Feb-Sun-16-Feb
Hi All,
Am working to get this implemented on my Printrbot. Came across this series of videos which make it very clear how to set up and calibrate
part 1: http://www.youtube.com/watch?v=awsI9bMndJA
part 2: http://www.youtube.com/watch?v=6msLOR_EfKc
part 3: http://www.youtube.com/watch?v=YpiOsetkIRg
This is done on a Prusa i3 with Ramps 1.4 but it makes a number of things clear that I wasn't able to gleen from this thread.
Obviously, the first thing that Printrboard folks will need to figure out is how to flash the board at will :P
KDog
Postby pomonabill221 » 2014-Feb-Mon-00-Feb
PBplus V2 kit.
pomonabill221
Postby nepaholic » 2014-Feb-Mon-03-Feb
Hi
Sorry can't upload pictures to the tapatalk app.
If you look on the schematics of your printrboard picture you uploaded it is the pin on the left with the number 7
This pin in the firmware is number 11
Please add the following to your firmware in te pins.h section for your printrboard
#ifdef NUM_SERVOS
#define SERVO0_PIN 11
#endif
Hope this helps
nepaholic
Postby pomonabill221 » 2014-Feb-Mon-04-Feb
OH OK! I see where the Pin11 comes from! That is in the firmware and NOT on the physical board... that would be pin 13 since the order of the pins is "zigzag" (odd on one side, even on the other... a typical IDC pinout). signal name "PC1" or port C1 That was throwing me off when you said the upper left pin.... I get it now.. DUH! :lol:
Thank You for the info! I will give it a try tomorrow.
Thank You! ;)
PBplus V2 kit.
pomonabill221
Postby nepaholic » 2014-Feb-Tue-10-Feb
nepaholic
Postby pomonabill221 » 2014-Feb-Tue-14-Feb
Thank you for the code and the info!
I did stumble across a three part youtube video on this mod, although it was for a different printer but was VERY similar code wise.
All the steps you provided are the same that was in the video, I just didn't mod the pins.h file and I think that is where Flip was having problems.
I haven't gotten back to it... other things came up that "got in the way", but I will try again today (IF time permits), but I did a "dry run" of the leveling (without the command to extend my probe and just relied on the "emergency" z stop), and it worked GREAT!
Once I get my probe to extend, I should be in business!!!! Just a matter of fine tuning positions and offsets... then I'm OFF!!!!
Thank you for your help!
PBplus V2 kit.
pomonabill221
Postby nepaholic » 2014-Feb-Wed-02-Feb
Yes that's right.
If you have the servo uncommented in the configuration.h then you also have to define the servo in the pins.h. Otherwise like you say the firmware won't compile correctly and you get a error.
If you don't use a servo and you want to flip out the probe by hand you have to comment
//#define NUM_SERVOS 1
nepaholic
Postby pomonabill221 » 2014-Feb-Wed-03-Feb
I was kinda guessing that this was my problem, but I didn't know where to look.
This kind of error was "hinting" that because the servos were being defined, the firmware didn't know what to do with the servos, or where they would connect.
Thanks for the hint/tip!
Still haven't tried it YET, but I cannot wait to!
PBplus V2 kit.
pomonabill221
Postby pomonabill221 » 2014-Feb-Wed-20-Feb
PBplus V2 kit.
pomonabill221
Postby pomonabill221 » 2014-Feb-Wed-21-Feb
PBplus V2 kit.
pomonabill221
Postby nepaholic » 2014-Feb-Thu-02-Feb
Oh sorry I have to check my firmware again tonight.
One question, do you have a LCD?
I had similare issues with overfilled bytes. It just mean that your memory on the printrboard is full.
I had to disable my LCD to get it running.
Or you also can disable accurate bed leveling, but then your bed will only probed on 3 positions.
nepaholic
Postby pomonabill221 » 2014-Feb-Thu-03-Feb
Hi Nepaholic;
That would be great if you could check.
No, I don't have the LCD.
I could trim the configuration.h and/or the pins.h down to make things fit, I think?
I do like the concept of the accurate bed leveling as I could make the autolevel probe more points... might try commenting out the lcd related stuff and see if that would work.
I though that I was trying to stuff 2 pounds of stuff into a 1 pound bag!
Thanks again for your help!
BTW... do I have to use the marlin-marlin v1, or can I use the marlin-bedlevel-v2? Is the marlin-marlin v1 a trimmed down set of header files?
PBplus V2 kit.
pomonabill221
Postby nepaholic » 2014-Feb-Thu-11-Feb
Hi i attached some of my files.
-the servo holder is designed for the original printed printrbot.
-the file probe is also designed for the printed printrbot. you have to get some magnets to use this(r=2,h=5mm)
this design work awesome but you have to flip out the probe manualy. the magnet snap and hold very well.
- the last file is my working firmware. it is v1 from printrbot.
servo.stlprobe.stlprintrbot_with_BAL.zip
nepaholic
Postby pomonabill221 » 2014-Feb-Thu-14-Feb
WOW! Thank You!
VERY helpful and I will go over it with a fine toothed comb to see what you did! Heck, I may learn something! (surprise surprise!).
Thanks again
PBplus V2 kit.
pomonabill221
Postby lwalkera » 2014-Feb-Thu-16-Feb
Laine Walker-Avina
lwalkera
Postby KDog » 2014-Feb-Thu-18-Feb
Awesome! Thanks for the files. I was getting ready to glue my servo to the side of my x-carriage :P
KDog
Postby pomonabill221 » 2014-Feb-Thu-19-Feb
PBplus V2 kit.
pomonabill221
Postby nepaholic » 2014-Feb-Thu-23-Feb
Hi
Well I think this might work if you use the PB LCD display.
I have many problems with this firmware and my panelolu. I can't get it running together
nepaholic
Postby pomonabill221 » 2014-Feb-Fri-19-Feb
Well I have HAD SUCCESS!!!! I even tried accurate bed leveling and specified a 3 (3X3 matrix) and it worked great!!!
Thank you nepaholic for your help!
One problem I am having...
IF I manually home the x/y using G28 x0 y0
then G28 z0,
then G29... this is where things go weird. The autolevel does start BUT the probe does NOT go to the "left probe bed position" but just starts at the homed x/y position.
BUT if I click on home all axes in repetier the x, y and x home ( or only G28 which homes x then y then moves to bed center and homes z), and the z axis moves up 10 mm and stops.
Then I issue a G29, x is homed but y is the first probed point and IS at the correct Y position "front probe position" (it moves back to the offset position (not home)).
I did see the lines in con..h that are
#ifdef Z_SAFE_HOMING
#define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28)
#define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28)
Is this where the bed centering after homing is coming from? Not a biggie but was curious.
Also, rather than run an RC servo, I would like to pull a solenoid (with a power fet of course), so I need to know if I can have the PWM output set to 100% duty cycle, or is there another pin that is a digital output that I can use? I tried setting the extend angle to 360, but the output from the board just went to a 50% square wave. Anything higher would result in the duty cycle "wrapping around" so that idea didn't work.
It would also have to stay on during auto level. The PWM output runs for a few cycles then stops, so even triggering a mono wouldn't really work.
This is getting VERY close to BLISS!!!
Thanks!
PBplus V2 kit.
pomonabill221
Postby thawkins » 2014-Feb-Sat-00-Feb
A couple of questions
I have all my hardware setup, with the reflective ir sensor and its working really well as a normal zstop, with the normal non-bedleveling code.
So i set the sensor to trigger 3mm below the end of the nozzle, and sure enough if home z with the normal code in place, the nozzle ends up 3 mm above the bed.
The sensor is to the left of the nozzle. About 10mm on the x, the y offset is 0 and the trigger point is now 3mm below the tip of the nozzle.
Ok, load the bed leveling code [bedlevel-v2.hex]
So i have
........... standard stuff to set steps/mm etc basicaly output from m503 on non leveling firmware.
M211 x150 y100 z150 ; set bed size
M212 x-10 y0 z-3.0 ; probe offset
G28 x0 y0
G29
G1 z10 f100
G1 x50 y50 f4000
G1 z0 f100
! Bang extruder crashes into deck on last move, breaks plastic z coupler.
So here are the questions
1. How exactly do you specify tbe probe offset, based on my spec, to left of nozzle by 10mm, same y, and below nozzle tip by 3mm, is what i have above correct?
2. Whilst probing is going on, is there anyway to set the z height it starts probing down from, i need it to return to a point at least 15mm above the bed on each probe, otherwise the sensor gets confused, it has to approach the bed from at least twice its sensor depth. The current code seems to drag the probe across the bed to tbe next measurment point, and only raise it a very small amount.
3. Is there any way to disable the autobed leveling support and return to being a simple standard zstop driven system without having to swap firmware again.
I'll try and load some video of what is happening once i manage to repair my z coupler .
Postby nepaholic » 2014-Feb-Sat-03-Feb
nepaholic
Postby pomonabill221 » 2014-Feb-Sat-03-Feb
This is getting VERY exciting!!!
My preliminary (VERY rough estimate of extruder vs. probe offset), is X= 47mm and Y= 6mm. I just measured with calipers and by eye, just to see what would happen and how it worked... I will perform accurate offset measurements later though.
My auto bed leveling portion of my config..h is:
#ifdef ENABLE_AUTO_BED_LEVELING
// these are the positions on the bed to do the probing
#define LEFT_PROBE_BED_POSITION 15
#define RIGHT_PROBE_BED_POSITION 135
#define BACK_PROBE_BED_POSITION 185
#define FRONT_PROBE_BED_POSITION 10
// these are the offsets to the prob relative to the extruder tip (Hotend - Probe)
#define X_PROBE_OFFSET_FROM_EXTRUDER_DEFAULT -46.00
#define Y_PROBE_OFFSET_FROM_EXTRUDER_DEFAULT -5.4
#define Z_PROBE_OFFSET_FROM_EXTRUDER_DEFAULT -3.70
#define Z_RAISE_BEFORE_HOMING 5 // (in mm) Raise Z before homing (G28) for Probe Clearance.
// Be sure you have this distance over your Z_MAX_POS in case
#define XY_TRAVEL_SPEED 5000 // X and Y axis travel speed between probes, in mm/min
#define Z_RAISE_BEFORE_PROBING 10 //How much the extruder will be raised before traveling to the first probing point.
#define Z_RAISE_BETWEEN_PROBINGS 5 //How much the extruder will be raised when traveling from between next probing points
I still need to find out how to get a constant signal out of the board to control my solenoid though... I am just trying this out using the "main" Z endstop, and it working great except the startup problem I posted in my previous post, but this is not a big one for me right now....
I attached my config..h I renamed it to configuration_h.txt because the board won't allow a *.h attachment. Just change the extension the .h as viewing in notepad is not formatted correctly.
PBplus V2 kit.
pomonabill221
PBplus V2 kit.
pomonabill221
PBplus V2 kit.
pomonabill221
Postby nepaholic » 2014-Feb-Sat-12-Feb
Pomonabill, where is your probe? On the left or right side of the extruder?
nepaholic
Postby pomonabill221 » 2014-Feb-Sat-13-Feb
My probe is on the right hand side.
Here are a couple of pics....
PBplus V2 kit.
pomonabill221
Postby nepaholic » 2014-Feb-Sat-14-Feb
Oh ok. Could you please try this
#define LEFT_PROBE_BED_POSITION 62
#define X_PROBE_OFFSET_FROM_EXTRUDER_DEFAULT 46.00
nepaholic
Postby pomonabill221 » 2014-Feb-Sun-00-Feb
I tried your values and the X position is WAY off from what I had.
My probe is a little past center in X.
If is set the default to -46.0, the probe still starts past center of X.
(I do have the 8x8 bed by the way), so the numbers above only sample a small portion of the bed and the square sampled is offset from center.
Here is a video of the different values in configuration.h
The first part is the values from above post, and the second post (even though I said new values) are my old values
https://www.dropbox.com/s/893jm94jb8y8he3/compare.mp4
The first thing I do is 'home all" in repetier and the extruder ends up in the middle of the bed.
Sorry about the focus... my camera lost it for a moment!
Hope this helps.
PBplus V2 kit.
pomonabill221
WOW what happened?
All of a sudden this thread went quiet?
I don't know if my earlier question was missed, but I would like to know if there is a way to get an output from the controller for use with a solenoid (with a driver of course).
The output would go hi to turn on the probe and low to retract the probe.
Is there any way to use the PWM and command 100% duty cycle rather than an angle, and have the output active all the time the probe is to be extended?
OR another pin on the controller that is a digital pin.
I couldn't find anything OBVIOUS in the *.h files that gave me a clue....
I'll do some more looking though.
PBplus V2 kit.
pomonabill221
Postby nepaholic » 2014-Feb-Tue-18-Feb
Hi. Sorry I'm very busy the last days :( and I do not have an answer to your questions because this is little to advanced for me. ;)
nepaholic
Postby KDog » 2014-Feb-Tue-19-Feb
Can't you connect the probe to a fan controller? You just need an on and off correct? You can control a fan in firmware.
KDog
Postby pomonabill221 » 2014-Feb-Tue-22-Feb
@nepaholic
No problem... I was only concerned because this thread seemed to become dormant.... was just wondering if something "bad" happened.
@KDog
Yes, I could use an unused fan controller pin as all I need is an on/off like you said, and not a PWM signal. The original fan IS a PWM signal.
I could even use a spare extruder heater output (the board supports 3 extruders doesn't it?) or an extruder step/direction output as I think they are digital (although step might be a pulse train for stepper speed, but still a digital output).
I would just need to know how to define the pin (in configuration.h and pins.h) so that it isn't a PWM output. I guess my main stumbling block for this kind of thing is how a pin is defined as a PWM/digital output or input (if it is a bidirectional pin). Where could I get this information? Arduino site? (I don't want this to turn into an Arduino training thread)
If the pin from the uP isn't brought out to a test pad/header, I can solder a wire onto the uP pin... done it before so no problem. (don't cringe too much.. just takes time and some magnification!)
PBplus V2 kit.
pomonabill221
Looking at pins.h, there are a few pins that look interesting, like led_pin, ps_on_pin, kill_pin, alarm_pin (these are for a motherboard type 8 though... rats)... I would think these are digital and not pwm outputs?
Also heater_1_pin and heater_2_pin. These are already defined to a pin so I might try one of them.
PBplus V2 kit.
pomonabill221
Postby pomonabill221 » 2014-Feb-Sat-02-Feb
So I have been trying to decifer the pin mapping in pins.h so that I can use a digital output rather than the PWM output for my solenoid...
GAWD is this confusing!
I found the panelolu page about the easy way (yeah right), and he has a table listing the signal names/physical pins/marlin pins/fastio pins.... WHAT A MESS!!!!
Some of the pins used are defined in marlin.h and some are fastio.h, it seems like the limit switches use the fastio mapping and the steppers use marlin.
All I want to do is change #ifdef NUM_SERVOS
#endif
to use say exp0:PE0 (physical pin 33/marlin pin 8/fastio pin 32)
How the h**l does one use a different pin for a digital output? What mapping needs to be changed?
Is SERVO0 a variable name and doesn't define a PWM so I could change the line to SERVO0_PIN 8 (but pin 8 is already defined in pins.h as Y STOP PIN) but is mapped in fastio.h to physical pin 10 PB0...
can this mapping be done?
VERY confusing ( to a non programmer with very little experience and alot of reading)!
OR is there some way that I can get the original pin 11 to toggle rather than PWM?
PBplus V2 kit.
pomonabill221
Postby KDog » 2014-Feb-Sat-02-Feb
I made some progress with my home-built Printrbot Original. I'm running an Azteeg x3 as the controller and it doesn't have "servo" pins. Had to figure out where to hook up the three wires and finally did. Am now getting servo movement when I input the M401 and M402 commands. The only question I have now is that the servo activates when I turn on the power supply and switches back when I connect the host. Is this normal?
Just need to get the fan pins to work now :P
KDog
Postby nepaholic » 2014-Feb-Sat-09-Feb
Yes that's normal kdog. My do the same
nepaholic
Next
