SilverFingers wrote:Would it be as simple as buying longer rods and replacing them?
I think I'm going to head to Lowe's later this week and pick up some longer rods.
Should they be made out of a certain type of metal?
Bob-StPaul wrote:Does Lowe's sell smooth rod? I don't recall seeing smooth rod at any hardware store...
JonS wrote:SilverFingers wrote:Would it be as simple as buying longer rods and replacing them?
I just yesterday took delivery of some parts from McMaster-Carr for this purpose. I'm upgrading my z-axis threaded rod to M8 and going over to a dual-nut with compression spring set up. When ordering I decided I high as well try to add a few inches to the z-axis.
I bought the following:
1 90024A080 Metric 18-8 Stainless Steel Threaded Rod, M8 Size, 1-Meter Length, 1.25 mm Pitch
2 90690A055 Metric Brass Hex Nut, M8 Size, 1.25 mm Pitch, 13 mm Width, 6.5 mm Height, packs of 25
3 94125K839 Metric Compression Spring, Music Wire, 39MM Overall, 11.0MM OD, 1.00MM Wire, packs of 5
4 6112K15 Hardened Precision Metric Steel Shaft, 8 mm Diameter, 800 mm Length
I intend to cut the rods and install them this weekend.
(I also bought a 6" x 6" borosilicate (Pyrex) glass plate for my heated bed, but that's a different subject.)
RetireeJay wrote:I think that all the Printrbots share the same firmware. There is a hard-coded limit, but it is at least 200mm because the PB Plus can go that high. There's a whole long thread in this forum about extending the Z axis even further for modified Printrbots
viewtopic.php?f=21&t=2239&p=28820&hilit=z+axis+height#p28820
- but I think you should be able to reach 200mm without modifying your firmware.
Lemm wrote:And what have you done in fact ? Firmware update or just setting the limits in Repetier higher ?
mrsamnc wrote:So what X/Y/Z lengths are you going after? What length did your Z rods end up being cut to? The 800mm rods are quite pricey.
JonS wrote:1. I updated to lwalkera's unified firmware: https://dl.dropboxusercontent.com/s/vr95m92an5p94av/Marlin-unified-v2.hex?token_hash=AAGpXJZRrD62dkNN1sOBX2GFjbo0cqSGJPGPNAmlzUew8A&dl=1
Lemm wrote:wow and printtime ??
DJNOS1978 wrote:Why is everyone only extending the z-axis? Is the x and y limited to firmware? Why not just "flip" it?
REPRAP SQUAD wrote:I would assume that you could load up the new firmware that is designed for longer axis's on the jr v2. That should allow you to at least e tend to the size of the new larger v2. At least tgats what I would do and save myself a huge firmware headache.
DJNOS1978 wrote:So it is very possible, although more difficult, to extend the x and y axis also? Is the firmware the limit to how big a printrbot can be?
DJNOS1978 wrote:I will go read some more. But from what you are saying....Any modification will need new firmware. How would I know which firmware to get? If I wanted to go for the super z axis what firmware is suggested? Is it in the package?
