by Tdeagan » 2013-Jul-Thu-22-Jul
Lotsa progress.
- I learned how to create new ReplicatorG machine definitions, so it's working well, but more happily for me;
- I finally read enough to learn that the pull-ups for the Ramps endstops are
internal to the processor and not part of the circuitry I see on the set of endstops that came with the Ramps kit. Meaning that I can use the stock Printrbot endstops that are already in place. I was able to get the configuration.h in Marlin happy and now faithful Pronterface is working happily with the Ramps 1.4 board. All axis happiness and perfect homing.
I'll write all this up in part 2 of my dual extruder setup series.
Now I need to decipher the surprisingly rich set of menu commands on the LCD!
If the spool of 1.75mm ABS would arrive I should be able to start using my dual extruder Printrbot Plus!
Thingiverse Profile:
