Printrbot Talk Forum • View topic - Z Axis Couplers on old Plus
Postby RetireeJay » 2018-Feb-Mon-20-Feb
This may be applicable to other Printrbots from the 2012 - 2013 era.
I have a new Prusa MK3 on order, and in order to prepare to make a comparison with my existing Plus, I decided to print a Benchy. One thing that I noticed was that in some parts of the Benchy there were irregularities along the Z axis - where a wall or corner would be wavy in the Z direction instead of smooth. I played around with "the usual suspect" - namely the number of microsteps or full steps per layer in Z, but making these changed did not improve the appearance of the result at all.
Upon closer examination, I realized that the variations matched the pitch of my Z screw exactly (18 turns per inch). So this made me wonder if my couplers from the Z motors to the threaded rods were at fault, like not perfectly concentric or somehow causing slight unintended vertical motion superimposed on the desired motion. Using my dial caliper, I carefully measured the Z motion every 0.1mm for 3mm and compared the actual size of each step to the theoretical size of each step. I found that there was, indeed, a once-per-revolution pattern of going above and below the ideal step size.
So I designed and printed new Z axis couplers.
I was surprised when I disassembled the original couplers to see how the vinyl sleeve on the motor shaft was such a poor choice to establish good concentricity.
After the upgrade, the standard deviation of the motion in the Z axis was roughly cut in half.
And Benchy looks better, although still not as good as I'd hoped.
Re: Z Axis Couplers on old Plus
Postby Mooselake » 2018-Feb-Wed-13-Feb
I used the so-called , Lovejoy couplers here in the states. Mine came from eBay iirc. Prior to the purchased ones I used a (not sure if that's the exact one I used, thought I'd posted some pictures but can't find them), not sure if the fancy aluminum and red plastic version was any better.
