Printrbot Simple LED Lights
Postby bcrazycramer » 2017-Oct-Thu-01-Oct
Hello,
This[url] https://printrbot.com/shop/led-strip//url] article says I need to update the firmware to use these LED lights. Is there an easier way to use them? The firmware updater for my MAC just sits there and says its downloading the firmware when I choose Printrbot Simple from the drop down.
Thanks,
Brandon
bcrazycramer
Re: Printrbot Simple LED Lights
Postby RetireeJay » 2017-Oct-Thu-06-Oct
Macs use a different way to flash the firmware than Windows computers. See the Wiki (the red-beige-white button next to the "Search..." box at the upper right of the main Printrbottalk screen)
