Printrbot Talk Forum • View topic - Printrboard F6 LCD support? (simple metal with heated bed)
Postby teknogeek1300 » 2017-Oct-Mon-03-Oct
Using 0.6 flashed hex(official). I've soldered the headers on, used a few general guides, but no results with a 4bit LCD(super cheapy).
Basically trying to confirm if 0.6 hex support LCD. I'm interested in monitoring with the LCD, not necessarily controlling. Temps, and times to completion essentially.
teknogeek1300
Re: Printrboard F6 LCD support? (simple metal with heated be
Postby cbxbiker61 » 2017-Oct-Mon-05-Oct
PrintrBot pretty much gave up on supporting the LCD's. The Printrboard just doesn't have enough storage, i.e. it's half of the normal boards being used today. I designed a custom QT app that I run on my workstations to control/monitor the printer status. OctoPrint is controlling the printer. Interestingly enough I also have the same interface (touchscreen) running on my OctoPrint Pi so I can control it at the machine when necessary, i.e. loading/unloading filament.
In this screenshot you can see the two panes that control/display the printer. Normally I drag the video feed over the control panel until just the status bar of the control panel shows so it doesn't use as much screen space.
Postby teknogeek1300 » 2017-Oct-Mon-12-Oct
Would a viable step be attempting to modify a Marlin firmware down to a suitable size for just displaying print percentage and estimated time?
Other than that, I have been reading a lot about rasberi pi's? Are they essentially using them as computers to control the system?
teknogeek1300
Postby cbxbiker61 » 2017-Oct-Mon-15-Oct
Postby teknogeek1300 » 2017-Oct-Wed-16-Oct
teknogeek1300
Postby cbxbiker61 » 2017-Oct-Wed-17-Oct
Postby frankv » 2017-Oct-Wed-18-Oct
Yes, a RPi (Running OctoPrint/OctoPi) connects via USB to a printer and presents the user with a web-based GUI. You upload gcode or stl files to the RPi, then tell it to print them.
frankv
First blob a success!
Postby Mooselake » 2017-Oct-Fri-15-Oct
Postby cbxbiker61 » 2017-Oct-Fri-18-Oct
Postby Mooselake » 2017-Oct-Mon-14-Oct
From poking through the recent github issues turning off arc support might create enough space to make it work. Slic3r had experimental arc support for a while (which worked pretty well for me at the time), but it hasn't worked for years. I don't think Cura ever had it. Don't know about S3D, Craftware, or the kissy slicer but suspect they're arcless also.
I'm a big arc fan, but from what I read some time ago Marlin turned arcs into greater than stepsize straight lines instead of <ducks> doing them properly at the highest possible resolution.
