by RetireeJay » 2017-Jul-Tue-22-Jul
It's absolutely possible. How to do it depends on which specific model of Printrboard you have.
The original circuit, before the probe came out, used a 4.7k pullup resistor, and the end-stop switch held the pin at ground until the switch was touched. On Rev D boards, the 4.7k pullup resistor was actually built-in to the ATMEL chip. On Rev F boards, you have a transistor in between the external pin and the ATMEL Z sensing input pin, so there's a inversion. Depending on the model, there may or may not be a pullup resistor in the circuit on the input side of the transistor (some probes have "open collector" outputs; others have active pull-up and pull-down circuitry). You will have to do a bit of research.
If you want to avoid having to modify the firmware, then you'll need to emulate the probe's high and low states depending on whether or not you are "triggered". Once you do that, then simply never issue a G29 command. A G28 Z0 will suffice to lower the carriage until it triggers your switch. You will want to have a convenient way of precisely adjusting the trigger point. And it will be up to you to get the plane of the bed parallel to the plane of X-Y motion of the hot end.
Several of us old-timers don't have probes and don't want them. A good switch and a trammed bed work just fine with ultimately less hassle.
