Will a Makerbot-style microswitch board work w/printrboard?
Postby musk » 2017-Jun-Thu-01-Jun
I have a couple of these microswitch boards kicking around, and I'm hoping to put them to use in a homemade printer. Does anybody know if they can be used with a printrboard? Maybe even the stock firmware?
Printrbot Metal Plus (2x)
Printrbot Simple Metal (2x)
musk
Re: Will a Makerbot-style microswitch board work w/printrboa
Postby RetireeJay » 2017-Jun-Thu-04-Jun
Umm... it probably will work. What is your reason for asking? Why not just buy the bare switch, which is much cheaper? When I looked at the Makerbot web site, the only thing I could see that would be an advantage for this PCB assembly is the indicator LED. Printrbot has published the Bill of Materials for their printers, and they even suggest a vendor (DigiKey) for parts like the standard switches.
The Printrboard only needs to use two leads for mechanical switches (the ones on the X and Y axes). It's only the Probe that needs power and thus needs a third lead. (The Printrboard connectors do have three leads available for those geeks who want to experiment with active devices like optical sensors, for example, but that's hardly ever done for X and Y)
Postby musk » 2017-Jun-Thu-13-Jun
Only because I already have a couple of these. Over the years I've accumulated a bunch of hotends, printrboards, motors, and aluminum extrusion so I'd like to build some of that stuff into a new printer.
musk
