by RetireeJay » 2017-Jun-Thu-04-Jun
Umm... it probably will work. What is your reason for asking? Why not just buy the bare switch, which is much cheaper? When I looked at the Makerbot web site, the only thing I could see that would be an advantage for this PCB assembly is the indicator LED. Printrbot has published the Bill of Materials for their printers, and they even suggest a vendor (DigiKey) for parts like the standard switches.
The Printrboard only needs to use two leads for mechanical switches (the ones on the X and Y axes). It's only the Probe that needs power and thus needs a third lead. (The Printrboard connectors do have three leads available for those geeks who want to experiment with active devices like optical sensors, for example, but that's hardly ever done for X and Y)
