Rev F5 question
Rev F5 question
Postby spenceju » 2017-Mar-Fri-17-Mar
Hi,
1. Does anyone know how much current this board can handle if I add a heated bed to my printrbot play? I've heard that most boards are around 10-15 amps but I can't find this info anywhere.
2. Does anyone know if this board has the equivalent of PS-ON pins that allow octoprint/raspberry pi to turn on and off an ATX power supply? I'm looking at the board and see some pins but none that are labeled PS-ON like on a RAMPS board.
Thanks, I appreciate any help
spenceju
Rev F5 question
Re: Rev F5 question
Postby RetireeJay » 2017-Apr-Sun-12-Apr
By "this board" I assume you mean a Printrboard. Yes, Printrboards can handle the current for heated beds used with Printrbot printers. Some clone boards have inferior copper plating on the board, but boards you buy from Printrbot have good high-current capability.
When you drop the ATX power supply coming in to a Printrboard, the board is pretty much powered down. (Some circuits can still get power from a USB connection, but not many.) So I'm not quite sure how you would tell a Printrboard to activate the "on" circuit for an ATX power supply once it's been turned off. The command exists in Marlin, but it's not clear which, if any, pin it maps to on the Printrboard.
Re: Rev F5 question
Postby PxT » 2017-Apr-Sun-15-Apr
RetireeJay wrote: The command exists in Marlin, but it's not clear which, if any, pin it maps to on the Printrboard.
The Printrbot fork of Marlin does not define this pin (PS_ON) at all so the M80 command becomes a no-op. M81 still works to turn off all the steppers, heaters & fans but it won't do anything to the power supply.
Re: Rev F5 question
Postby blort » 2017-Apr-Mon-21-Apr
if you are doing octoprint on a pi, the raspi is actually the component that triggers atxpsu on/off.
blort
Re: Rev F5 question
Postby spenceju » 2017-Apr-Tue-22-Apr
Thanks everyone for the replies!
Yes I was asking about a printrboard, I should have made that more clear. I read in a previous thread, "If you try to draw too much current through the Heated Bed connector on the Printrboard, the connector will overheat. The connector can handle about 12A safely (when you use all 4 pins)." This may have been referring to a Rev E and not a Rev F version of the printrboard. I noticed the heated bed upgrade being sold by printrbot is 20A. It seems safe to assume this is how much the printrboard Rev F can handle. I've since learned I can use a solid state relay to use as much current as I want.
It is true that the raspi is the component that triggers atxpsu on/off when using octoprint. It looks like using PS_ON isn't possible with the printrboard. Perhaps it's possible to write a program on the raspi that recognizes when octoprint is sent a .stl file and have it switch a relay that is connected to the atxpsu
spenceju
Re: Rev F5 question
Postby RetireeJay » 2017-Apr-Wed-06-Apr
spenceju wrote:I read in a previous thread, "If you try to draw too much current through the Heated Bed connector on the Printrboard, the connector will overheat. The connector can handle about 12A safely (when you use all 4 pins)." This may have been referring to a Rev E and not a Rev F version of the printrboard. I noticed the heated bed upgrade being sold by printrbot is 20A. It seems safe to assume this is how much the printrboard Rev F can handle. I've since learned I can use a solid state relay to use as much current as I want.
Correct. (BTW, there was never a Rev E in production; the predecessor to Rev F was Rev D.) The screw terminals on the Rev F board should be good for 20A. There are several threads in the forum that discuss exactly how to implement an external SSR.
